Thread: Coil Pressure Drop
15-04-2008, 05:03 PM #1
Coil Pressure Drop
I would like to know what would be the effect of LOWER pressure drop in the evaporator coil for low temp. application.
I have a scenario, where coil output should be quite low as compare to comp. output but still the suction pressure is not dropping.
I was wondering, if more feeds in the coil is the cause.
Regards,
15-04-2008, 05:26 PM #2
Re: Coil Pressure Drop
jwasir,
We need more information. Model numbers of the equipment and any other control numbers, TXV etc.
Regards.............Powell
15-04-2008, 08:41 PM #3
The application is reduce the ambient air temp. from 90F to -30F.
The air volume is 500 CFM.
There are 2 stages, first is supposed to bring the temp to 30F and second is supposed to bring it to -40F.
Now first stage is doing the job.
In second stage I have 1/2" coil 2 FPI with 5 feeds.
Electronic expansion valve -- 5.5 SH.
Presently, all I can get is 5F air temp and SST is -19F (R-404a)
I was wondering if I have more feeds in the coil.
The coil output, as per software is 30,000 BTU.
The comp. output is 102,000 BTU but still the suction pressure is not dropping.
I'll really appreciate by getting your feed back to the problem.
A question about the pressure drop in coil .
By jackcn in forum FundamentalsReplies: 20Last Post: 13-12-2008, 05:10 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
coil pressure drop
By unibar in forum Technical DiscussionsReplies: 0Last Post: 04-08-2007, 06:22 AM -
TEV capacity related to pressure drop
By DaBit in forum CPU OverclockersReplies: 8Last Post: 06-12-2002, 05:11 PM
