    mattarooni's Avatar
    mattarooni Guest
    I Think I Have a Problem with AC
    i have a dx r22 air con system with dual compressors on one circuit, on cooliing the pressures are way low but on heat there fine press are 75kpa suct and 1350kpa discharge please advise
    11,025
    Re: I Think I Have a Problem with AC
    As a service manager I would have thought that you should be supplying the answers
    However, some more detailed information of the running conditions is required before sensible answers can be formulated.
    Usual things....superheat, sub cooling temperatures etc.
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, mattarooni
    welcome to RE forums...
    Quote Originally Posted by mattarooni View Post
    ..... I Think I Have a Problem with AC .....
    seems not only you, we too
    anyhow to get advice or answer you should give us more data....
    Quote Originally Posted by Brian_UK
    ........ more detailed information of the running conditions is required before sensible answers can be formulated.
    Best regards, Josip
  1. A strange problem
    By MuhengineeR in forum Air Conditioning
    Last Post: 27-10-2010, 05:21 PM
  2. York Chiller Excessive Purges Problem
    By imranmd in forum Commercial
    Last Post: 07-03-2008, 05:13 AM
  3. Toshiba RAV SM/SP1400 defrost problem
    By SteinarN in forum Heat Pumps
    Last Post: 20-02-2008, 04:25 PM
  4. Oil carry over Problem in Refrigeration Unit
    By imranmd in forum Industrial
    Last Post: 27-08-2007, 03:09 PM
  5. Condensation Problem At Door to Freezers
    By mmarch in forum Air Conditioning
    Last Post: 17-10-2005, 02:42 PM
