Thread: Scotsman DCE33 icemaker
08-04-2008, 01:06 AM #1
Hi there, I'm a newby here and I'm trying to find out just whats wrong with my home icemaker. Its a Scotsman DCE33 thats about 5 years old now. I keep the intake area clean & vacumed out about once a quarter, but recently its started making less & less ice. Also, the ice it does make, appears to have a lot of air in the cubes. Any suggesstions from anybody as to how I can fix this. Thanks!
08-04-2008, 03:55 PM #2
Re: Scotsman DCE33 icemaker
Bump!!!!!!!!!!!
08-04-2008, 10:04 PM #3
Hi sounds like a water problem , possibly needs descaling inside the spray jet assemblies. How old is the machine and when was it last descaled as this is a common problem .
09-04-2008, 12:02 AM #4
I was going to say welcome to the forum but I think you need to recognise that the answers you receive here are from a worldwide membership.
To expect an answer within 3 hours and to show impatience as well does not bode well I'm afraid.
If you want quick service then I suggest you contact you local refrigeration expert.Brian - Newton Abbot, Devon, UK
09-04-2008, 01:14 PM #5
Hi mate i would first check if you have refrigerant in your system then check temperature and pressure depending on the refrigerant it uses then you can see what you dealing with?
Scotsman ice machine DCE33
By Ania in forum Trouble ShootingReplies: 4Last Post: 16-09-2007, 03:28 AM -
K40 Icemaker
By Andy AC in forum CommercialReplies: 22Last Post: 26-04-2007, 10:27 PM -
scotsman ice-machine
By yourxmen2910 in forum Technical DiscussionsReplies: 7Last Post: 28-08-2006, 10:21 AM -
User Manual Scotsman Ice One AS/E
By JohnMac in forum Trouble ShootingReplies: 1Last Post: 09-07-2005, 11:17 AM -
Scotsman Ice Making Machine.
By Latte in forum Trouble ShootingReplies: 10Last Post: 01-09-2004, 10:16 PM
