Thread: r22 to r507 conversion
06-04-2008, 08:22 PM #1
need feedback from those that have converted from r22 to r507 - looking at three seperate projects - 1. copeland screw SHL 6000 currently r22 zero degree evap glycol fluid 2. air cooled chiller carlye 06e or 06d comps r22 comfort cooling 3. york recip r22 air cooled air to air comfort cooling.
comments on refrigerants other than r507 are welcome
07-04-2008, 04:30 PM #2
Re: r22 to r507 conversion
I may be working on a similar project and am interested in comments on this subject also. In the meantime I have found some information that is related to the subject and thought it should be shared...
http://refrigerants.dupont.com/Suva/...ng_roberts.pdf
http://www.hvacrinfo.com/cope_ae_bulletins/TAE1177.PDF
http://www.hvacrinfo.com/cope_ae_bulletins/TAE1105.PDF
http://www.hvacrinfo.com/cope_ae_bulletins/TAE1284.PDF
http://www.hvacrinfo.com/cope_ae_bulletins/TAE1248.PDF
http://www.hvacrinfo.com/cope_ae_bulletins/TAE1273.PDF
http://www.fmi.org/energy/CD2006/pre...s_Welter_2.pdf
http://www.process-cooling.com/CDA/A...100000f932a8c0____
Hopefully others will have some thoughts to share also.If all else fails, ask for help.
07-04-2008, 06:07 PM #3
Here are some additional sources for reading...
(this one has some very good information)
http://www.uneptie.org/ozonaction/in...les/1861-e.pdf
https://www.bitzer.de/_doc/k/kt-630-2.pdf
http://www.bitzer.de/_doc/a/a-501-14.pdf
(see page 17)
http://www.bitzer.de/_doc/k/kt-650-2.pdf
(some general information in the next two links)
https://pgw100.portal.gases.boc.com/...ical_Guide.pdf
http://rc.danfoss.com/TechnicalInfo/..._pf000f102.pdf
(see chapters 7 & 7)
http://www.agas.com/pdfs/pdf%20fridg...cketManual.pdf
Happy readingIf all else fails, ask for help.
08-04-2008, 10:36 PM #4
ES-22a (a drop-in replacement for R22) works great in an average central A/C unit. I'm not sure how well it would work in a chiller, but it is a mixture that must be liquid charged. No oil change needed either.
"If Hannah was an air handler, I would be a condensing unit so I could open her TXV and pump my refrigerant through her coils." - a HVAC friend of mine
R507 instead R404a?
By Friobernal in forum RefrigerantsReplies: 49Last Post: 09-04-2011, 12:42 AM -
R507 in an R134a compressor: any danger?
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 21-12-2009, 12:44 AM -
SI conversion
By mcjo tech in forum Tools and CalculatorsReplies: 10Last Post: 06-05-2007, 01:43 PM -
R507 in an R134a compressor: system design
By DaBit in forum Technical SpeculationsReplies: 17Last Post: 01-05-2003, 09:25 AM -
Effect on design evaporator by using R507 instead of R22
By lappee in forum RefrigerantsReplies: 2Last Post: 18-09-2001, 05:15 PM
