Thread: Mits. SRK 25 ZC-S Fault
13-01-2011, 12:51 PM #1
I have a customer with a Mits unit that is faulty. I have visited the customer but found the unit running fine. The usual thing when I am not there is plays up again. Apparently the RUN light flashes twice,Then it may shut down , but not allways. Any ideas? The unit is 5-6 years old and given no prob. before. Any fault codes that I find on the forum don't seem to include this fault. It may be that the customer is miss reading the flashes/lamp readings.
13-01-2011, 06:38 PM #2
Re: Mits. SRK 25 ZC-S Fault
If the timer lamp is on and the run lamp flashes twice - room temp sensor error.
If the run lamp keeps flashing and the timer lamp flashes twice - outdoor heat exchanger liquid pipe sensor error.
If the run lamp flashes twice and timer lamp flashes twice - compressor rotor lock - bad news.
Andy
vrv3 au fault
By transit 1 in forum Air ConditioningReplies: 6Last Post: 04-11-2010, 10:19 PM -
Mitsubishi 1500 fault code fault
By pie man in forum Air ConditioningReplies: 9Last Post: 06-05-2010, 09:30 PM -
Supra common fault - usually misdiagnosed.
By carrier_trained in forum TransportReplies: 3Last Post: 15-04-2010, 08:56 PM -
mits elect split fault
By paul_h in forum Air ConditioningReplies: 7Last Post: 27-01-2009, 11:24 PM -
Fault with Tango cassette
By airefresco in forum Air ConditioningReplies: 8Last Post: 19-09-2007, 08:42 AM
