Thread: Safe practices
05-04-2008, 04:16 AM #1
Safe practices
When I was a teen, a ham radio mentor taught me to only work on transmitting gear with one hand in your pocket and while wear rubber sole shoes. The point was that lethal voltage was contained inside. You never allowed another part of your body to complete the circuit accidentally while probing voltages. Instinct might cause one to rest the free hand on the enclosure while the other hand holds the probe. Hence the advice to put your free hand in your pocket. It was a matter of developing a safe habit that is second nature.
The point wasn't so much that you have one hand in your pocket but the concept that you never have both hands touching the gear. The risk is not only electocution, but risk of injury from one's reaction to a shock. People are hurt or even fall from the roof tops when they receive an unexpected jolt.
I learned to hold both test leads with one hand, or better yet connect the meter and then activate the circuit under test once out of harms way.
I watched tonight in horror while a utility company worker serviced a mercury vapor lamp out front. He was outfitted with a fiberglass bucket boom to keep him safe from earth connection. He grabbed one test lead in each hand and probed the circuit to assure it was live. He had at least 240 volts potential and possibly 480 VAC, 60 Hz between the meter probes while holding one meter probe held in each hand.
I know probes are insulated to a kv or more and they should be safe if they are new and in good condition. What if there is a circuit fault and the voltage is way higher than expected? (Remember, there was a complaint about the lighting circuit that caused the service visit) What if the meter leads are worn or there's a temporary loss of balance causing one to grab the earthed structure with a free hand to gain balance?
Good habits last a lifetime. I would like to hear other safe work rules around this gear. We all have different mentors.
05-04-2008, 12:55 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Safe practices
Buy this for 30$ and be safe:
http://tinyurl.com/g66gf
It is always in my pocket, and I love it!
Of course, always confirm findings with multimeter.Last edited by nike123; 05-04-2008 at 12:58 PM.
05-04-2008, 08:48 PM #3
Re: Safe practices
Ah the one hand rule, I'm suprised they did not even try to teach this in trades school, they failed to mention that one should stand away from the gauges when opening a high pressure cylinder valve incase of blow out.
05-04-2008, 10:55 PM #4
Re: Safe practices
i too was taught this and only use croc clips to earth as i was taught elec would take the shortist route right across your ticker,but you still see lots of bad practise and here of folk getting hurt.worst one i saw was a sparkie cutting through an 415v armoured cable with a hack saw poor guy was just about killed
C&G Ammonia Safe Handling 2078
By Grizzly in forum TrainingReplies: 5Last Post: 28-03-2008, 12:14 PM -
Safe Systems of Work
By frank in forum Legal-Business-MarketingReplies: 11Last Post: 25-10-2007, 02:55 AM -
NH3 safe handling certificate
By guapo in forum IndustrialReplies: 3Last Post: 25-02-2007, 01:40 PM -
Safe disconnect?
By giro in forum FundamentalsReplies: 3Last Post: 01-01-2006, 10:50 PM -
EU Safe Handling Legislation
By Derek in forum TrainingReplies: 2Last Post: 19-04-2002, 12:17 PM
