    Feb 2008
    505
    21
    valves from compressor
    this is a picture of a discharge valve from a prescold compressor it was removed from a reclaim unit and the valve plate that it was removed from have you seen a valve reed bend like this befor
    Feb 2008
    Norway
    57
    446
    Re: valves from compressor
    Ouchh, nasty sight.
    Looks like it has been a very high temperature. Is it the discharge valve reed which is bent? Could it be the temperature has been high enough to soften the material in the valve reed enough to make it bend like that?
    Split Croatia
    57
    6,151
    36
    Is it posible that hydraulic hammering and overheating is responsible for this bending?
    Feb 2008
    Norway
    57
    446
    I think that is more likely that hydraulic hammering and overheating is responsible for this bending.
    Agree about hydraulic hammering on a inlet valve, but it looks like it's the discharge valve which is bent. This will also be the hottest valve.
    Feb 2008
    Las Vegas, NV
    67
    330
    Quote Originally Posted by martinw58 View Post
    martinw,
    This is definitely an overheating issue.
    The most obvious effect of overheating is the breakdown of oil and carbonization at the discharge reed and discharge side of the valve plate. Copper plating and carbon is a byproduct of heat.
    This puppy must have been extremely hot to bend the reeds. I would think there would also be more damage in the crank.
    Oct 2006
    1,843
    21
    Quote Originally Posted by powell View Post
    martinw,
    Yep, yep, yep seems to be running a tad hot
    Is it a single comp or is it one of a pair? you also state that the comp was on a reclaim unit. I take it, it was a heat reclaim unit?
    There is a lot of heat generation there.
    cheers taz.
  1. Testing Inverters
    By fridge doctor in forum Air Conditioning
    Last Post: 15-06-2011, 06:52 AM
  2. Compressor loading, cooling, and range of operation.
  3. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
  4. Mitsubishi compressor lock
    By marc5180 in forum Air Conditioning
    Last Post: 08-10-2007, 05:48 PM
  5. Compressor pumping efficiency
    Last Post: 25-02-2004, 10:50 PM
