Results 1 to 22 of 22
    IL
    13
    Refrigerator Catches Fire
    HI.
    lately we are experiencing some total refrigerator burnout in customer premesis.
    the appliances are turkish made and are about 6 years old.
    the fire seems to start off the defrost timer.
    does anybody know anything about this rather concerning phenomenon?
    Feb 2007
    2,473
    45
    Re: Refrigerator Catches Fire
    No, I never had the privilege to work on any Turkish kit.
    But it must been an electrical fire, there are 2 reasons for these to start.
    -Overheating components (incl. cables)
    -Dirt or grime creating a short circuit
    Dirt or grime is self-explanatory, so lets look in to the overheating options:
    -Over loaded and incorrectly fused.
    -Undersized component (see point above).
    -Poor connection.
    -Poor breaking performance of breaking component.
    As we are talking about kit that's been running for years, I would say that either the dirt option or the last 2 options under [over heating] above must be the culprit.
    The switch in the defrost timer might have weakened with time.
    Cables (or connectors) might have gotten corroded.
    Connectors might have loosened.
    No doubt there are other options I forgotten, hopefully other people will continue the list.
    IL
    13
    thank you for your answer .
    I think you have covered the issue.
    The real problem is that the whole appliance went in a blaze, and this is something that must of been retarded by the raw materials and never did.
    So far we have had some 4 cases.
    The big question is :do we call a "self recall" and start replacing those timers or do we wait until the producer will order such an act?
    Feb 2007
    2,473
    45
    They are not in commercial kitchens and suffers from grease build-up behind them by any chance?
    Mar 2008
    54
    273
    They could have got water in the electrics is another theory ??
    Oct 2006
    Bucks, U.K.
    71
    604
    Have you informed the importer of these units?
    They would hold the liability if the unit was proven to be faulty, and it sounds as if you have experienced more than one occurrence.
    IL
    13
    thanks.yes i have informed them and for the moment they are catching their breath trying to figure out what to do.
    I do not trust these guys, for they do not have the same safty standards like American producers such as whirlpool.
    IL
    13
    NO no they just go on fire and take the whole premesis along.I could mail you some very educative pictures if you gave me your email Ad.
    thanks
    Feb 2007
    2,473
    45
    Email them to me and I will put them on my site for the world to see...
    IL
    13
    thanks its in your mail now!!
    Oct 2006
    Bucks, U.K.
    71
    604
    If you've got a number of these units in service, have you done an audit / examination of all the units to determine if you can spot any early signs of overheating.
    The problem (as suggested by the viking) could be due to under-rated component or wiring, bearing in mind that when operating on 120v the current is doubled....
    It would possibly be prudent to replace the suspect item....this pro-active approach would be a good defence in any litigation. It could be argued that you should inform all your customers that a possible problem exists with these units....they can then decide to replace them or continue using them at their risk.....either way it offloads responsibility from yourselves.
    Do you have a National Safety organisation that you can report this to who can then put pressure on the importers and issue a warning notice.
    It might be possible to fit a metal shield above and/or between the defrost timer and the (plastic?) body of the fridge to offer some barrier to limit the spread of fire. (This is only an idea, and not a recognised solution).
    Jul 2006
    norfolk
    737
    Unhappy Re: Refrigerator Catches Fire
    i've seen a few Beko fridge/freezers that have had the defrost timer have corroded and that the appliance has caught fire some from water onto of compressor has got on to the defrost timer and caused i to corrode. worst one was the whole kitchen caught fire
    IL
    13
    have you had any vestel cases ?
    Jul 2006
    norfolk
    737
    nope not seen any vestel yet,guessin that they aren't any good or is it just certain model no's as have that wiv from other makes one model is very good hardly any faults the odd stat here and there and next model no load of crap always system blockage but they both run on R600a. do u do contract work for vestel ?
    IL
    13
    We are the official aftersale provider for some of their OEM Brands.
    Jul 2006
    norfolk
    737
    any chance of details so can see if we can get some work over here for them as know they sold here as well
    Aug 2007
    Perth
    44
    Have you performed an insulation test on these fridges? Are Saftey switches(RCD's/ELCB's etc.) fitted on the circuit they are connected to? RCD's in my experiences are extemely good fire preventitives. just a thought. Not going to fix the root of the problem but!
    stserkan's Avatar
    stserkan Guest
    Quote Originally Posted by MICHAE View Post
    thanks
    I am doing the same job like you and I have read your posts about refrigerators,if you send me these photos , i would be glad. These pictures would be so helpful about solving the problem. And i need another fovour from you, would you give me more details about the fires,What do you think the problem is(other than the defrost timer)?MY mail is stserkan@gmail.com
  19. #19
    Oct 2008
    North East
    1,050
    Quote Originally Posted by The Viking View Post
    Viking did you ever upload these pics cant find them on your site?
  20. #20
    colnol3's Avatar
    colnol3 Guest
    Good morning to you from London. I have been studying domestic fridge and freezer fires here in the Uk for several years now. We have approx 300 reported cases of fire each year but many more near misses are not reported.
    we have noted many failures of defrost mechanisms and I would suggest the most common failure is moisture creating a short across one of the terminals. We are experiencing a number of Turkish units, it is fair to say that they are amongst the cheaper and most used. We also have capacitor and compressor switch failings which are probably the three most common fire causes. Most consumers are totaly unaware of the flammability of European domestic fridges and freezers. The average fridge/freezer produces approx 2.5MW of heat output when ignited and the rapidity of spread makes this the most dangerous domestic appliance in the house. Can talk fires all day, please contact if more info. Superb site.
    Mike
  21. #21
    Jul 2006
    norfolk
    737
    turkish ones are most them BEKO? as seen a few of them now,surpised more havent caught fire as poorly made
  22. #22
    stserkan's Avatar
    stserkan Guest
    Mike,
    What do you think about the other refrigerators which are produced by other companies in terms of the flammability.Could you tell me more about the reported cases of fire?Which refrigerators do you suggest us to buy for our safety?
  1. Fire - run capacitor, high resistance connection?
    By Kenedt in forum Technical Discussions
    Last Post: 13-08-2007, 07:07 PM
  2. fire shutdown
    By mwizard in forum Air Conditioning
    Last Post: 20-02-2007, 08:50 PM
  3. kerry foods vans catching fire
    By stevemartial in forum Transport
    Last Post: 23-12-2005, 07:47 PM
  4. Cost effective Freezer/Cooler Fire Detection
    By Marvin in forum New Technologies
    Last Post: 14-12-2004, 09:20 PM
  5. Dont call me, call the fire brigade!!!
    By 750 Valve in forum Chit Chat & Service Stories
    Last Post: 27-02-2004, 10:34 PM
