Results 1 to 20 of 20
    s7m8a's Avatar
    s7m8a Guest
    Thumbs up CARRIER - experimental coil design
    Has anyone heard of Carrier's trials with automotive radiator style evap and condenser coils? The design is " supposed" to be more efficient, weigh less & be less prone to refrigerant leaks versus fin coils.
    Nov 2005
    Ireland
    Re: CARRIER - experimental coil design
    Following is the difference between the new aluminum coils and the copper coils
    Compactness: 1 row vs 3 to 4 rows for copper coils
    Coil Efficiency: 10% improvement
    Unit Efficiency: 2% improvement
    Refrigerant Charge: 30% reduction
    Coil Weight: 60% reduction
    Galvanic Corrosion: 3.5X improvement vs. standard coil
    Cleaning: High pressure water w/o damage
    s7m8a's Avatar
    s7m8a Guest
    How long will it be -roughly- for the "radiator" style coils to become available & replace conventional fin coils? I also appreciate your time & all the info, fin.....
    Feb 2008
    Saudi Arabia
    52
    can you give me more info about the new product
    khalid.alhasan@gmail.com
    Nov 2005
    Ireland
    Quote Originally Posted by s7m8a View Post
    Carrier have been using the coils for over a year now with no problems. We had only one issue here in Ireland and that was a plumber putting a piece of unistrut through it. Changing the coil was easy enough as it is piped with a few bolts and gaskets.(no welding of pipe-work) Also, the cost of the coil is about 1/10 of the old type.
    May 2006
    India
    82
    1,013
    What is the application of these coils. Can they be used for low temperature. Are they finned tubes ?
    Could please provide a link where more information could be availed.
    Jul 2005
    Southern Hemisphere
    9
    The coils are manufacture by Delphi in the states don't get too excited as there have been lots of problems with leakage in particular on Carrier 30XA thunderbolt screw chiller and delphi are reviewing the design.
    u.k
    12
    Worked on 20 units+ with no problems with any of them.
    Jul 2008
    94
    Hi all, Just searched for info on these coils used on some Carrier chillers and found this thread.
    I wonder if anyone has any updates on the delphi condensers in particular relating to coil leaks. Have any coils been replaced with a traditional copper/aluminium fin condenser?
    Thanks in advance.
    Phil
    Jul 2005
    Southern Hemisphere
    9
    Quote Originally Posted by ptsac View Post
    Thanks in advance.
    Phil
    I'm unaware of any coils being replaced in with standard coils unless requested by the end user.
    Main problem with these coils has been damage from vibration during transport, I have not had any issues with coils that have been replaced and as long as the manufacturers rigging/transport instructions are followed..
    Leaks can be repaired easily with some soft solder and and two pieces of aluminium.
    Jul 2005
    Southern Hemisphere
    9
    Quote Originally Posted by willow View Post
    If it's a competition I have worked on over 90 chillers that have these coils with an average of 8 per machine (16 in some cases) thats 720 coils.
    Mar 2009
    KZN, South Africa
    64
    2,212
    The design principles behind these coils are very simple, actually. I am surpised that the quoted performance is still so low. It seem that some more development still needs to be done, knowing Delphi. I suspect that most will be condensers, which are fairly straightforward. The evaps will be a lot tougher to get stable.
    I'd love to see real application feedback on their performance, robustness & endurance.
    To manufacture them at competitive prices should be no problem at all.
    I want to see these in copper alloys, not aluminium.
    Jul 2007
    Italy
    55
    Someone has a direct experience in repairing a leak on this type of coils?
    This was my major concern the first time i saw one....
    Thanks.
    Jul 2008
    94
    Quote Originally Posted by Groid View Post
    Cheers Groid, thanks for the info.
    Do the inlet and outlet flanges have an "o" ring seal or is it a gasket ? I hav'nt been to site so working off reports.
    Thanks Phil
    Mar 2009
    KZN, South Africa
    64
    2,212
    Quote Originally Posted by fintan View Post
    I'm going to have a go at this statement.
    If the cores are of aluminium brazed construction, then the fins will be totally annealed & are as soft as tin-foil. One hard spray on the front face will bend the fins flat, in no time at all.
    A CuproBraze product (anneal-resistant copper), will take all kinds of punishment. Problem is that the copper world is so incredibly sleepy in developing this technology. I have tried every which way to get folks moving into these products, but all they do is blow bubbles.
    Jul 2005
    Southern Hemisphere
    9
    Sealing material is a stainless dual skin washer with a neoprene type inner seal, They can normally be re-used but I wold request some be sent with the coil if you are replacing, Also be careful they are dead centre and torque them to 20Nm no more or you will damage the seal
    Jan 2010
    Alabama
    9
    Anyone have pictures or a link?
    Dec 2008
    42
    all this talk about and no name.. give us a hint atleast about what to search in google...
    BerryC516's Avatar
    BerryC516 Guest
    Quote Originally Posted by charlie View Post
    Thanks.
    These type of coils (microchannel) can very easily be repaired with a two-part epoxy. Red epoxy is a decent one as is a kit called "repair bond kit"--at least I think that is what it is called from Johnson manufacturing. Basically, you just block one or two of the 100 plus (typically way more than 100) "microchannels" going in any one direction...no real impact on performance.
    Jul 2007
    Italy
    55
    Thank you for reply BerryC516.
    I have one more question (sorry to be a pain) the repair with a "two part epoxy" can be for sure a good option for circuits working with a low operating pressure refrigerant (like R134a for example).
    What about circuits working with a high operating pressure refrigerant like R410a?
  1. Replies: 12
  2. water cooling coil design
    Last Post: 30-04-2008, 09:54 AM
  3. Coil design?
    By The MG Pony in forum Fundamentals
    Last Post: 20-06-2006, 12:32 AM
  4. Dx coil design
    By abbasi in forum Technical Discussions
    Last Post: 16-12-2004, 12:41 AM
