Thread: Grasso oil pump
    fife
    56
    8
    Grasso oil pump
    We have a grasso oil pump that has a worn bearing resulting in a leaky shaft seal. Has anyone tried to replace the bearing(s) in a grasso oil pump.
    cheers
    Geoff
    Aug 2009
    india
    54
    7
    Re: Grasso oil pump
    if its RC11 we do change the bearing bush and also we have modified gear set with cover plate (i.e double ended shaft )
    Aug 2009
    Norway
    48
    Re: Grasso oil pump
    Hi Geoffg!
    What kind of Grasso compressor do you have?
    Somerset
    69
    4,706
    Re: Grasso oil pump
    Quote Originally Posted by geoffg View Post
    cheers
    Geoff
    Hi Geoff
    What you don't say is what type of Grasso you are refering to?
    If you let us know which type you are asking about.
    You can get a more specific answer.
    Basically yes the are changeable what you do depend upon the type!
    Cheers Grizzly
    Somerset
    69
    4,706
    Re: Grasso oil pump
    Geoff.
    This may appear a stupid question!
    But why do you say that a leaking oil pump bearing is causing the shaft seal to leak.
  1. liquid ammonia pump calvitation
    By Kathleen in forum Trouble Shooting
    Last Post: 20-05-2011, 02:18 AM
  2. Daikin lift pump
    By Slim R410a in forum Air Conditioning
    Last Post: 13-07-2009, 11:12 PM
  3. Help with condensor pump
    By Bakerbj in forum Air Conditioning
    Last Post: 14-06-2009, 12:39 AM
  4. frostles heat pump
  5. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
