Thread: Grasso oil pump
03-04-2008, 05:38 PM #1
Grasso oil pump
We have a grasso oil pump that has a worn bearing resulting in a leaky shaft seal. Has anyone tried to replace the bearing(s) in a grasso oil pump.
cheers
Geoff
07-08-2009, 12:36 PM #2
Re: Grasso oil pump
if its RC11 we do change the bearing bush and also we have modified gear set with cover plate (i.e double ended shaft )
07-08-2009, 02:59 PM #3
Re: Grasso oil pump
Hi Geoffg!
What kind of Grasso compressor do you have?
07-08-2009, 06:06 PM #4
08-08-2009, 07:55 AM #5
Re: Grasso oil pump
Geoff.
This may appear a stupid question!
But why do you say that a leaking oil pump bearing is causing the shaft seal to leak.
liquid ammonia pump calvitation
By Kathleen in forum Trouble ShootingReplies: 23Last Post: 20-05-2011, 02:18 AM -
Daikin lift pump
By Slim R410a in forum Air ConditioningReplies: 10Last Post: 13-07-2009, 11:12 PM -
Help with condensor pump
By Bakerbj in forum Air ConditioningReplies: 23Last Post: 14-06-2009, 12:39 AM -
frostles heat pump
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM
