    AutoZaf's Avatar
    AutoZaf Guest
    Bosch Fridge Freezer warm on the outside
    Morning all, Newbi here.
    I have a Bosch KGU32121GB that my wife tells me is warmer than usual on the left hand side panel. Should we expect this unit to be warm to the touch on the outside?
    The units abuts a kitchen cabinet on the right hand side, but only for the height of the freezer. The left hand side is completely open, expect for when the kitched door is open, but the door doesn't sit tight to the fridge freezer anyway.
    It's not the whole panel that's warm, but more of a hotspot at the front edge, starting about 8 inches below the top of height of the freezer door.
    Thanks in advance for your help.
    Split Croatia
    57
    6,151
    36
    Re: Bosch Fridge Freezer warm on the outside
    Check your user manual and ensure that free space around unit is as specified there.
    Oct 2006
    Bucks, U.K.
    71
    604
    Some units use a skin condenser (akin to a chest freezer) so they are designed to get warm on outside.
    Has your unit got a black pipe and wire condenser on the back?
    The other design feature is that they run a pipe around the freezer door area to keep that area warm.
    As Nike says...check your instruction manual, and make sure ventilation is adequate...both at bottom and on top rear of unit.
    AutoZaf's Avatar
    AutoZaf Guest
    Many thanks for the replies. I'll pull it out and dust it down. There are possibly a whole bunch of toys underneath.
    Jul 2006
    norfolk
    737
    On most refrigeration there is a “hot-pipe” that runs around the door aperture of the machine, this applies to most refrigerators, fridge freezers and freezers, that is designed to heat any excess condensation helping it to evaporate away. To see condensation around the door, or to feel heat there, is not unusual and is part of the normal operation of the unit.
    Jun 2007
    Cyprus
    73
    252
    For your info, the pipe around the door of the freezer is there to prevent condensation forming under certain humidity conditions... In a worst case scenario the freezer door would freeze to the casing.
    Jul 2007
    Australia
    1,845
    Normal, it stops the freezer cabinet sweating and the door sticking.
    When you pull a ice cold drink out of the fridge it sweats after a while, the outside of the drink gets wet with condensation. Freezers have warm pipes around the outside of the cabinet to prevent condensation forming on the outside of the freezer. This prevents rust on the cabinet and the door icing up.
    Commercial units even have electric heaters to help. Being warm on the outside is normal for a freezer.
  1. fridge warm freezer cold?
    By babsnsarah in forum Domestic
    Last Post: 30-04-2011, 04:24 PM
  2. Replies: 6
    Last Post: 25-10-2010, 01:25 PM
  3. Wirlpool FF Issue - fridge warm, freezer cool
    By kinetic100 in forum Domestic
    Last Post: 02-04-2008, 01:36 AM
  4. Bosch - fridge warm freezer cold
    By turnerma in forum Trouble Shooting
    Last Post: 19-02-2008, 01:17 PM
  5. Zanussi - fridge is warm but freezer is cold.
    By Bob Ball in forum Trouble Shooting
    Last Post: 11-02-2007, 04:59 PM
