Thread: R407C Questions
    Mar 2008
    Philadelphia
    R407C Questions
    AMAZING FORUM!
    I'm new to this forum and actually new to this industry. I just graduated from college, and started a new job and being in expert in Refrigerants is my first task. I am interested in refrigerants for A/C systems in rail cars.
    I have some questions with respect to R407C that I hope you can help me with:
    1- Assuming the unit (Condenser) is designed for R-22, how big a problem is the glide of the blend? I understand efficiency and performance lower down. by how much? any other differences?
    2- Since leakage can be a problem in the mobile environment, fractionation of this blend could be a concern. How would the maintenance department know that fractionation has occurred and when to replace the charge
    3- If a fractionated R407C charge is recovered and not severely contaminated, can the refrigerant manufacturer reclaim it, restoring its original composition?
    Also, are there any new R22 replacement refrigerants on the horizon that are either near-azeotropes or azeotropes?
    Any help is GREATLY appreciated!
    Thanks a lot guys! and keep up the good work!
    Marwan
    Feb 2008
    Las Vegas, NV
    67
    330
    Re: R407C Questions
    marwanm,
    To start, here is the link to Copelands view on converting from R22 to R407C. There is some good information here.
    http://www.hvacrinfo.com/cope_ae_bulletins/95-14.PDF
    Here is Duponts link to R407C
    http://refrigerants.dupont.com/Suva/.../suva407c.html
    Powell
    Re: R407C Questions
    Have a look at Isceon 59...
    http://www.eurocooling.com/articlerhodia.htm
    Mar 2008
    United States of America
    Re: R407C Questions
    Isceon M029 looks to be worth while.
    Re: R407C Questions
    Quote Originally Posted by the mojo View Post
    Sorry, I thought that I had the right number
    Mar 2008
    Re: R407C Questions
    No problem Brian.
    Could you put up the html for marwanm, don't have enough required posts yet.
    Mar 2008
    Philadelphia
    Re: R407C Questions
    Thank you guys for your help! I am assuming that Isceon M029 is the R-422D. Who manufactures Isceon?
    I will read the articles you gave me and I am sure I will still have few questions.
    Again, I really appreciate your help...
    M.
    Feb 2008
    India
    43
    28
    Re: R407C Questions
    K Need To Check The Acidic Effect Too
    Mar 2007
    Warwickshire UK
    723
    Re: R407C Questions
    For a/c engineers in Europe R407c was a nightmare dead end trip.
    R407c really is a complete waist of time.
    Looking back it would have been much better to have delayed R22 phase out to allow manufacturers to develop R410a equipment.
    Then we could have moved straight from R22 onto R410a.
    If you really want to learn about how to design an a/c system using R407c then I suggest you look at the old R407c Mitsubishi Electric City Multi VRF systems which had a refrigerant blend sensing CS circuit which allowed the outdoor unit to constantly estimate the ratio of R32 in the blend.
    Based in this data the system could trim its operation to suit. For instance it could blast some hot gas into the accumulator to stur up the liquid to reduce the fractionation which tends to happen at the accumulator. Lots of split systems & VRF systems had high pressure fault problems which the manufacturers did not want to talk about beacuse of this issue.
    At low compressor speed the accumulator get full of R134a & the compressor pumps R32 & R125 arround the system & trips on high pressure.
  1. Interview questions
    By zimbo in forum Chit Chat & Service Stories
    Last Post: 10-09-2008, 10:06 PM
  2. r407c chiller issue
    Last Post: 09-01-2008, 01:22 AM
  3. R407c
    By binman54 in forum Refrigerants
    Last Post: 16-12-2006, 09:57 PM
  4. questions
    By parry in forum Chit Chat & Service Stories
    Last Post: 31-10-2005, 08:46 AM
  5. R22 vs R407C.....................again!!
    By Abe in forum Air Conditioning
    Last Post: 24-07-2003, 12:21 AM
