    kinetic100's Avatar
    kinetic100 Guest
    Wirlpool FF Issue - fridge warm, freezer cool
    Hi guys,
    we've got a problem with the Wirlpool FF (85017471558 ) at my pad. This is a " total non-frost unit !!" and air from teh freezer comp is cirulated into teh fridge comp. In essence the problems are:
    * the freezer compartment freezes up after a few days.
    * the pump and circulation fan are on constantly
    * I've defrosted, checked the thermostat and the thermisters and they seem ok
    I've notice that when the freezer comp and fridge compartment doors are open, air circulates perfectly. Close the freezer door and the cirulation stops. Close both and nothing cirulates. This is a really stupid question, but could this be due to the door seals or do we need to regas the unit.
    Look forward to hearinhg from you guys.
    Keith
    Oct 2005
    Romania
    44
    Re: Wirlpool FF Issue - fridge warm, freezer cool
    [QUOTE=kinetic100;99670]Hi guys,
    Hi , kinetik
    I send to you electrical diagram and NTC temperature chart. If NTC resistence value "migrate " with few ohms , - 22 deg.C is , for electronic module , -2 deg , for example and all is wrong inside.
    Best regards
    Gramcor
    Oct 2006
    Bucks, U.K.
    71
    604
    Keith, welcome...we hope we can help you, but I think we will need a bit more info from you...
    Quote Originally Posted by kinetic100 View Post
    Is it a ARC7472/IX (850174715058)?....I cannot find an exact match to your model
    What are the temperatures of the Freezer and Fridge compartments.?
    You say the freezer compartment freezes up....do you mean the evaporator at the rear?
    It sounds as though you have a defrost problem....or possibly a door seal is not sealing or the door is not closing properly.
    Have you checked the defrost heater and circuit? There should be an overtemp cutout in circuit.
    I would expect the internal fan to run except when on defrost. The compressor might run 18hrs....is this unit freestanding or built in?....can it get rid of the heat? Both will result in the unit running longer.
    How did you defrost and for how long?...A lot of problems associated with ice build up in the air ducts to the fridge require 48hrs to fully defrost.
    Return air duct blocked?
    Close both and nothing circulates.
    kinetic100's Avatar
    kinetic100 Guest
    [quote=gramcor;99682]
    Hi guys,
    Hi , kinetik
    Best regards
    Gramcor
    Hi Gamcor,
    many thanks for taking the time to send the details and chart. I'll run through the details and other suggestions shortly.
    Cheers,
    Keith
    kinetic100's Avatar
    kinetic100 Guest
    [quote=Electrocoolman;99690]Keith, welcome...we hope we can help you, but I think we will need a bit more info from you...
    Hi Electrocoolman,
    thanks for your reply just tio answer your questions so far:
    >Yes it is an ARC7472/IX
    > 15 Degree C in Fridge and -18 in Freezer, with Ice build up at the front next some of the seals.
    > In a sense yes, the whole side and and top have a thick layer of ice from teh air circulating. I also end up taking all the panel out and defrosting the evapouration equipment. I think also ice builds up behind the panel where the fan is and pushes this out, so the fan is not aligned to the tube tup to the fride comp.
    > I though it is this because I ran little experiement. I put a small tube on one of the seals when closing the freezer comp. 20 mins later the fridge compartment had dropped 8 degrees C. Which lead on to the answer to your next question.
    > I think this isn't working correctly as nothing has shut off correctly. I left the said experiment running for 3 hours and the fridge comp reached 3 degrees C and freezer -20 degrees C
    >At no point does it appear to have shut off. I'm goign to have a look at the drain in the freezer comp this morning.
    > I have to admit, with a full fridge and freezer, we only defrosted for 6 hours (with help of the neighbours !)
    >No, it didn't appear so. I took the internal facia for controls in the fridge out of situ and with a tube at the bottom to catch fluid, poured hot water down. At no point did it appear that it was blocked as the water appear to flow the same each time.
    Best regards,
    Keith
    kinetic100's Avatar
    kinetic100 Guest
    Just to follow up exploratory work. I have now done the " boiling water down the drainage tube treatment" which seems to be a common approach when there are cooling sensor issues ( it seems to have saved some people teh cost of a new unit anyway). Just to report, the fridge definately for 2 hours stopped cooling when it reached the appropriate temperature.
    N.B cannot do a full defrost as missus and my daughter are ill.....
    Oct 2006
    Bucks, U.K.
    71
    604
    Hopefully not food poisoning ? !!
  1. fridge warm freezer cold?
    By babsnsarah in forum Domestic
    Last Post: 30-04-2011, 04:24 PM
  2. Replies: 6
    Last Post: 25-10-2010, 01:25 PM
  3. crazy 3rd-world idea: aircon from small fridge
    By lsemprini in forum Fundamentals
    Last Post: 29-05-2008, 01:10 AM
  4. Zanussi zebf 249n fridge warm, freezer cold
    By davemar in forum Domestic
    Last Post: 18-03-2008, 08:58 PM
  5. Zanussi - fridge is warm but freezer is cold.
    By Bob Ball in forum Trouble Shooting
    Last Post: 11-02-2007, 04:59 PM
