Thread: heat exchanger
    Mar 2008
    US
    74
    heat exchanger
    Hello,
    Both condenser and evaporator are heat exchanger. What type of heat exchanger are used in condenser, and what type for evaporator? (how to select heat exchanger for them?)
    Thanks in advance.
    David
    Apr 2006
    41
    1,620
    Re: heat exchanger
    First you calculate the total load in the box, determin the temp and RH you want, this will determin your evap duty and size.
    From there you work back wards the condenser will be the last thing sized.
    Mar 2008
    US
    74
    Re: heat exchanger
    Thank you MG pony!
    Mar 2008
    US
    74
    Re: heat exchanger
    How about the type of heat exchanger? like fin and tube, plate and tube....
    Jan 2006
    Croatia
    68
    2,261
    31
    Re: heat exchanger
    Hi, david2008
    Welcome to RE forums....
    Quote Originally Posted by david2008 View Post
    Hello,
    Thanks in advance.
    David
    selection of HE depends on use... and price
    then we have a media for cooling (for condensers) both air and water or only air/water (or maybe another liquid)....
    the same is with evaporators ... cooling only air or some liquid....
    .... they can be also PHE-Plate Heat Exchangers, S&T-Shell&Tube, TinT-Tube in Tube, Finned or with Plates on tubes...maybe some other type which I do not know
    hope this help a little..
    Best regards, Josip
    Mar 2008
    US
    74
    Re: heat exchanger
    Great! Thanks Josip. your post is helpful.
    David
    Apr 2006
    41
    1,620
    Re: heat exchanger
    Lets cut more to the chase and ask: What exactly are you trying to do? as the application determines what is used.
  1. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  2. Replies: 5
    Last Post: 14-09-2009, 07:33 AM
  3. frostles heat pump
  4. heat exchanger for small chiller
    By star882 in forum Fundamentals
    Last Post: 30-01-2007, 12:06 PM
  5. R134a <-> liquid heat exchanger design
    Last Post: 10-05-2002, 08:36 AM
