    Aug 2007
    Malawi
    35
    compressor ratings in horse power
    what is the relationship between motor power and pump power in a compressors. say how do you know a compressor power when you have motor power in watts. For example you have a compressor with name plate reading 220V 32A LRA. how can you make use of this to know how many horse power is a compressor
    Jul 2007
    Australia
    44
    1,857
    14
    Re: compressor ratings in horse power
    watts = voltage x amps
    horsepower is K-watts divided by 0.75
    70
    10,602
    52
    LRA = locked rotor amps which is nothing to do with the motor power or refrigerating effect of the pump.
    You need to refer to the compressor manufacturers' data sheet for the compressor model for duty ratings etc.
    Jul 2007
    Australia
    44
    1,857
    14
    You're right, for some reason I was thinking of FLA. My mind was wandering because I was trying to sort out the fan for the fedders split unit when I replied.
    70
    10,602
    52
    Quite understandable Paul, we only have so many brain cells in use at one time.
    Well, that's what I'm told by the wife
    May 2006
    India
    1,016
    14
    The compressor rating can be assessed on based on the refrigerant, Evap. Temp. and the Cond. Temp. Based on the rating the electrical load kw could be found from the compressor rating chart.
    Alaska USA
    66
    10
    Quote Originally Posted by themba View Post
    Compressor dose not have a any hose power. Motor dose.
    You can connect on same compressor at one condition 50 hp and other 100 hp. All depend on evap temp condensing temp etc... If really you want know how much hose power using on the motor you need hook up meters.
    tedre
  1. compressor horse power
    By ewart in forum Industrial Compressors
    Last Post: 27-07-2009, 05:39 PM
  2. SR2 50 models electric SBY diagonostics made simple
    By absolute-zero in forum Transport
    Last Post: 04-01-2008, 05:11 PM
  3. Horse power rating
    By Argus in forum Air Conditioning
    Last Post: 03-02-2005, 10:52 AM
  4. NEW 3-Phase IGBT Inverter Power IC
    By theberes in forum New Technologies
    Last Post: 01-03-2004, 01:10 AM
  5. motor horse power
    By mtoto in forum Fundamentals
    Last Post: 05-06-2002, 03:32 AM
