Thread: 134A to R22
25-03-2008, 12:07 PM #1
134A to R22
Pls, help...can we use R134a instead of R22?
25-03-2008, 12:55 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: 134A to R22
Read this, you will find there all you need to know about retrofitting R22:
http://tinyurl.com/yt9p78
25-03-2008, 01:03 PM #3
Re: 134A to R22
If your wanting to use the existing compressor and maintain the current temperature the answer would be no if this were the typical refrigerant or air cooled compressors. R-22 is a high pressure gas and R134a is a low pressure gas.
More information is needed, such as model numbers, application, etc. for a definitive answer.
25-03-2008, 04:20 PM #4
Re: 134A to R22
thanks for the reply & info ..
but i think the 1st link is not available:
25-03-2008, 04:31 PM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
25-03-2008, 05:11 PM #6
Re: 134A to R22
27-03-2008, 02:11 PM #7
Re: 134A to R22
duly noted...thanks again for the help & info
cheers & more power to this forum!!!
Refrigeration Capacity with R 134a
By Samarjit Sen in forum RefrigerantsReplies: 7Last Post: 02-06-2009, 02:28 AM -
r600a or 134a
By Minestrone Dave in forum RefrigerantsReplies: 16Last Post: 02-06-2008, 07:57 AM -
134a expansion valve question
By g_norman in forum Technical SpeculationsReplies: 3Last Post: 18-03-2006, 03:06 AM -
134a surge drum sizing
By Camille in forum RefrigerantsReplies: 0Last Post: 03-03-2006, 01:44 PM -
Charging 134a
By pirestani in forum RefrigerantsReplies: 1Last Post: 02-06-2002, 03:08 PM
