Results 1 to 11 of 11
Thread: Recovery unit
25-03-2008, 12:01 PM #1
Recovery unit
Hello
I need to recover large amounts of refrigerant, and I need a simple to use, not too large, and reliant unit.
I've tried units based on Bitzer compressors. They work fine, and are quite fast. The problem is oil from the compressor tends to end up at the recieving end. Despite filters, and oil separators.
I've also tried those small portable devices with oil free compressors. They don't work as fast as the first mentioned units, and they tend to overheat.
The problem here is that they are not built for running continously for many hours. (5-15 hours is normal) We often need to empty 60 litre cylinders of about 40 kgs of refrigerant each, or 900 litre drums of 30-600 kgs of refrigerant. Mostly 30-100 kgs from the drums. (The heel).
Does anybody know of any reliable, and effective unit for my purposes?
25-03-2008, 12:03 PM #2
Re: Recovery unit
Contact Polar Pumps 01302 751 253
25-03-2008, 12:41 PM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,175
- Blog Entries
- 6
- Rep Power
- 36
Re: Recovery unit
If you use Danfoss Turbocor oil free compressor you couldn't keep up with cylinder changes speed. And it is only 120 kg.
Just kidding. Or, maybe not!
25-03-2008, 03:24 PM #4
Re: Recovery unit
A small centrifugal liquid pump fitted to an electric motor works great if size is not a problem. We used one to move refrigerant from 1000kg pots through lines in our factory. The pump itself is 7/8 dia in/out and approx 5" dia centrifugal pump coupled to an electric motor.
25-03-2008, 03:35 PM #5
Re: Recovery unit
A pump for liquid sounds simple enough.
But, I want to pump gas, and all of the gas in the cylinder/drum. I wish to recover all of the refrigerant, but at the same time I wish for any possible oil content to be left in the cylinder to be empty.
25-03-2008, 04:08 PM #6
Re: Recovery unit
best then to just use your fast one with additional oil seps and or carbon oil absorbers.
19-10-2008, 05:08 PM #7
19-10-2008, 06:45 PM #8
Re: Recovery unit
Ona thought if the Op is still reading gasp style vain pump, they do both liquid & gas and are high speed!
01-11-2008, 01:19 AM #9
04-11-2008, 09:38 AM #10
Re: Recovery unit
Appion G5 twin.
05-11-2008, 09:33 PM #11
Re: Recovery unit
as previous----polar pumps,they have the answer as i have seen it, brad will bring it as hand luggage for a price.
Make a Recovery Unit
By shark26 in forum Tools and CalculatorsReplies: 12Last Post: 22-02-2009, 07:49 PM -
Thermo King OptiSet
By REEFER-TEK in forum TransportReplies: 4Last Post: 06-12-2007, 08:23 PM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 07:25 PM -
where to buy a Recovery unit
By plumbus in forum Tools and CalculatorsReplies: 3Last Post: 02-12-2007, 07:11 PM
