Results 1 to 18 of 18
Hybrid View
    Sep 2005
    South West
    129
    Fujitsu strange Whistling noise
    I wonder if anyone has had any experience of this?
    I have been contacted this weekend by a customer that we installed a 5kw Fujitsu WM inverter for last summer.
    His exact description is a strange high pitched whistling noise coming from the outdoor unit both when the system is running and when off. The system itself is working fine ,just seems to be producing this strange noise. I am going to pop in on wednesday to investigate but wondered if any of you had come accross this before??
    Many thanks
    Gareth
    Split Croatia
    57
    6,151
    36
    Re: Fujitsu strange Whistling noise
    It is probably faulty electrolytic condenser of power inverter.
    11,024
    Or, is it the sound of gas passing through a restrictor of some sort?
    Split Croatia
    57
    6,151
    36
    If AC doesn't cool or heat, then there is no flow of refrigerant.
    Sep 2005
    South West
    129
    Apparently all is working fine so i dont expect a leak. This is a constant whistle noise so i am thinking it may be electrical??
    11,024
    But it could be equalizing
    Split Croatia
    57
    6,151
    36
    Of course that it could be!
    Jun 2006
    204
    Does the noise stop when you shut off the mains? Magnetic cores, such as in switching power supplies can vibrate at their operating frequency. This happens when windings and core are not cemented in place during manufacturing. These assemblies are typically dipped or doped to prevent motion. Ceramic capacitors can also make noise in switch mode supplies.
    Jul 2007
    Australia
    1,845
    If it happens when the unit isn't running, it's usually the inverter power filter board or capacitors.
    Feb 2008
    stevenage england chav central
    44
    hello mate i would check inside the condenser as it sounds like its coming from there but maybe it might be the condenser fan motor is it the same pitch all the time? does it change in heating mode ? ive had a few fan motors on dakin inverter units making a whistling noise changed the fan motor and it stopped freaky
    declan
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by declan simmonds View Post
    declan
    Hi, Declan
    If you read carefully first post, you maybe found this sentence very interesting:
    So, where is the connection between fan noise and supposed fact (supposed because that is customer words) that this noise is heard when system is off?
    Feb 2008
    44
    oh in that case it must be the power inverter board humming duh ill get me coat
    Sep 2005
    33
    Hi Guys
    You have noise wether running or not & the unit runs ok. Maybe it's the wind whistling through the condenser.
    Frostycold
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Frostycold View Post
    Hi Guys
    Frostycold
    What if day is without wind?
    Hi pal
    Iv had the same thing,Mine was a tiny hole on top of the compressor check that. but it could also be equalizing.
    Dec 2006
    London & Surrounding Counties
    122
    Im pretty convinced this is just the perfectly normal operating sound related to an inverter drive. "It's a high pitched noise"........yeah that's the noise inverters make. "It's running perfectly-yeah that's because it's not broken".
    I fitted one last year, and was quite suprised at how noisy the Fujitsu's were on full song when. There a vast improvement on a fixed speed system in terms of noise emmission, but they still leave a lot to be desired especially if fitted in residential environments. That whining noise will do your head in.
    Theres no easier way (as someones suggested) than to isolate the supply to the outdoor unit-it should fade out over 20 seconds say.
    Finally-tell the client to stop there winging and pay the call out
    Tell us what your findings were hey?...............
    Split Croatia
    57
    6,151
    36
    Guys, read the description of problem more carefully. Half of these post would not existed if the original post is carefully read.
  1. TXV Whistling
    By Myrmydon in forum Trouble Shooting
    Last Post: 07-09-2011, 03:27 PM
  2. Hermetic strange sound.
    By fridg in forum Technical Speculations
    Last Post: 02-03-2008, 07:08 PM
  3. Noise Level
    By Cewek ITS in forum Technical Speculations
    Last Post: 20-09-2007, 01:47 AM
  4. Fujitsu or not?
    By LRAC in forum Air Conditioning
    Last Post: 29-08-2007, 09:45 AM
  5. Any Ideas? Worrying noise from Fujitsu ASY 30E
    By MrThin in forum Air Conditioning
    Last Post: 29-06-2006, 11:45 AM
