Results 1 to 18 of 18
    Feb 2008
    Sudan
    89
    DAIKIN VRV-WII Outdoor Units
    Hi Chaps
    I wonder if any one can help.
    I want to know what is a maximum actual cooling capacity of REWYQ10,20,30 ?
    Feb 2008
    Sudan
    89
    Re: DAIKIN VRV-WII Outdoor Units
    Quote Originally Posted by MRcoolingMAGIC View Post
    You mean RWEYQ10M.You can connect indoor units with a total capacity of 34 kw.It is compatible with all types of VRV indoor units.The only issue about these units is that a tap water supply is not strong enough it must to be a commercial 24 l / s.
    Thanks MRcoolingMAGIC. On the cooling capacity tables for RWEYQ10MY1 there are many capacities according to your conditions.This is a values of nominal capacities.What is the actual values?
    this is my conditions combination 100%, Inlet water temp 30C,water volume 96 L/min, and 19 CWB Indoor air temp.
    On this conditions the capacity of the unit is 26.7KW,this is the nominal capacity.I want to know what is the maximum capacity on this conditions.
    Feb 2008
    Sudan
    89
    Thank you MRcoolingMAGIC Where can I find this information [maxmum allowable capacity (34.7 kw)]? Can you give me a detailed location?
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by 2007eng View Post
    Try here:
    http://www.daikinac.com/landing.asp
    Feb 2008
    Sudan
    89
    What is the benefit of combination ratio exactly?
    Feb 2008
    Sudan
    89
    Do u mean (sum of indoor units capacity/sum of outdoor units capacity)?
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, 2007eng
    Hi Chaps
    maybe is not bad idea to search here...
    http://207.45.127.154/daikin/Default.aspx?tabid=142 ....seems complete Daikin tech downloads...a lot to read
    http://www.daikin.co.uk/default.jsp
    hope this is of some help
    Best regards, Josip
    Feb 2008
    Sudan
    89
    Well, I have a question which may solve my problem.
    The question is, what is the maximum indoor units index number can I connet with RWEYQ10,20,30M?
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, 2007eng
    see attachment ... but.... you must check all by yourself, here....
    http://207.45.127.154/daikin/Techdow...x?EntryId=1926
    not to claim anybody for mistake/s later on
    Best regards, Josip
    Attached Files Attached Files
    Feb 2008
    Sudan
    89
    Realy I don't Know How can I thank you Josip.
    Thanks.. Thanks.....infinity
    Feb 2008
    Sudan
    89
    Tel you what dude sit down learn a bit theory before you proceed to these very complicated systems called VRV.It is not a domestic fridge.Sorry this is how i see it.
    I found what is a combination ratio:
    combination ratio=(Sum of Indoor units index/100% index of Outdoor)
    That what I wanted. Thank u MRcoolingMAGIC.
    ulanda's Avatar
    ulanda Guest
    Hi there
    I am lookinng for the operation manual for the RWEYQ10M?
    Hope someone can help.
    Thanks in advance.
    Ulanda
    Feb 2008
    Sudan
    89
    Smile Re: DAIKIN VRV-WII Outdoor Units
    Quote Originally Posted by ulanda View Post
    Hi there
    Thanks in advance.
    Ulanda
    Well come ulanda.
    It is very difficult to attach the file, but take this link and you will find your request.
    http://207.45.127.154/daikin/Techdow...x?EntryId=1622
    Jul 2008
    London
    848
    You can over index of course...
    Multisync
    London
    Feb 2008
    Sudan
    89
    Quote Originally Posted by multisync View Post
    Multisync
    London
    Yes, But DAIKIN said the combination ratio does not exceed 100% (Recommended limit)
    Feb 2008
    Sudan
    89
    Wait wait, what do you mean by ( You can over index of course...).
    As example RWEYQ10 100% index= 250.
    You can not change this value in the formula(You can not use 110%...in the formula).But if you mean combination ratio over 100%; it is possible, but it is not recommended.
    Feb 2008
    Sussex UK
    54
    Heard you can over index up to 130%, due to not all indoor units bieng at 100% all at the same time. Be carefull of the refnet joints near the outdoor units,( within 2mtrs with an oil trap) and also if you are using it as an heat pump or heat recovery system, use the correct suction line fitting as one is 3/4 and one is 7/8, the also use a shared discharge and suction depending on the application! My advice is to read the installation guide at least twice... and don't throw any pipework connections away!
    Feb 2008
    Sudan
    89
    Quote Originally Posted by Thana View Post
    Ok Thana, and Thank u for your advice.
  1. Service checker Daikin
    By Cool100 in forum Air Conditioning
    Last Post: 22-03-2011, 12:53 PM
  2. Daikin not working... many problems
    By stankovicv in forum Air Conditioning
    Last Post: 11-12-2010, 09:01 AM
  3. Daikin, Why do we bother?
    By gwilliamson in forum Air Conditioning
    Last Post: 02-02-2010, 09:38 AM
  4. daikin controllers
    By declan simmonds in forum Air Conditioning
    Last Post: 10-07-2009, 10:54 PM
  5. Daikin Comp and inverter
    By WCC73 in forum Air Conditioning
    Last Post: 08-11-2008, 08:44 PM
