Thread: R290
02-07-2003, 10:15 PM #1
R290
I'm pretty much a newbie to refrigeration, and would like to know a little about using propane as a refrigerant. Just a couple of quick questions:
1)At room temperature (let's say 20 deg/c) what is the pressure that propane gas will liquify at?
2)If a system was measured as 150psi high side with ambient temperature @ 20 deg/c ambient, how much would this pressure vary? Let's say that ambient temperatures could go as low as 0 degrees and as high as 30 degrees. How high/low is the system pressure likely to go? Wouldn't want to risk any explosions, especially with hydrocarbons.
Many thanks!
Matthew
02-07-2003, 10:44 PM #21)At room temperature (let's say 20 deg/c) what is the pressure that propane gas will liquify at?
But assuming you mean 20C air flowing through the condenser, the SCT (saturated condensing temperature) inside the condenser will be somewhat higher, depending on condenser sizing, refrigerant charge, and airflow, and thus the pressure will be somewhat higher.
On the low end it would pretty much match ambient (0C) at 53.2 psig.Last edited by Gary; 02-07-2003 at 10:49 PM.
03-07-2003, 09:37 AM #3
Thanks Gary, that's exactly what I was after.
Matthew
R290 diagram
By mahive in forum RefrigerantsReplies: 5Last Post: 14-04-2011, 12:02 PM -
R290 Systems
By kasperDK in forum HydrocarbonsReplies: 13Last Post: 05-02-2011, 10:34 PM -
R290?
By andyh in forum RefrigerantsReplies: 15Last Post: 22-09-2007, 06:42 PM -
Some questions about system of R290
By sagittarius in forum HydrocarbonsReplies: 36Last Post: 31-05-2006, 04:27 AM -
R290 Care 50
By ralph feria in forum RefrigerantsReplies: 12Last Post: 24-02-2004, 02:53 AM
