Thread: Chiller to heat pump
20-03-2008, 05:15 PM #1
I was wondering if anybody could tell me if its possible, and what would be involved in modifying an existing air cooled packaged chiller so that it could heat water utilising the existing chilled water pipework and fan coils, but still able to changeover to cooling in the summer. I am not am design engineer so i cant provide you with any calculations etc, but would just like to know if and how its possible.
thanks in advance
Danny
20-03-2008, 06:00 PM #2
Re: Chiller to heat pump
Providing you have a good knowledge of the system then techicaly yes it is, you'd have to check to ensure your coil is of the right design for it, if it is add a reversing valve and add the needed electronics to drive it. Depending on the metering device you may need to add check valves or do some redasigning, add a bidirectional filter drier.
in short it can be don, but there is a good deal of work that must be don to do so.
20-03-2008, 06:23 PM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
20-03-2008, 07:19 PM #4
Hmmm true, depends largely on what type of heat exchanger he has. I do think I mentioned he'd have to check that though.
I have converted Window A/Cs to heat pumps with good success, I rewire it so in heating mode the fan will be locked into full speed and usualy keeps head pressures resonable. but it is mostly manual control, hence why I mentioned he only should try if he has deep understanding of it.Last edited by The MG Pony; 20-03-2008 at 07:21 PM.
20-03-2008, 07:20 PM #5
In addition to a reversing valve you would need to consider adding a suction accumulator to prevent flood back, defrost controls, outdoor TEV, non return valves across each TEV and fan speed controllers. Simple init?
20-03-2008, 07:23 PM #6
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
20-03-2008, 07:27 PM #7
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
VRV/VRF vs Chiller (heat pump)
By nike123 in forum Technical DiscussionsReplies: 8Last Post: 09-06-2011, 03:21 PM -
Capacity control
By sparrow in forum TrainingReplies: 44Last Post: 18-01-2010, 07:49 PM -
DIY heat pump 12kW
By kimusabi in forum FundamentalsReplies: 11Last Post: 17-10-2009, 07:50 PM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
heat exchanger for small chiller
By star882 in forum FundamentalsReplies: 4Last Post: 30-01-2007, 12:06 PM
