Results 1 to 18 of 18
    Jan 2008
    turkey
    5
    Oil Accumulation
    hi everyone!
    i'm very new in refrigeration and sometimes some big problems. this one is one of them well, i hope i could get my solution here.
    during the refrigeration cycle, some oil of the compressor flows with the refrigerant.while it is flowing into evaporator from capillary tube, oil accumulation happens in the entry of the evaporator. i wonder how can i prevent the evaporator from oil accumulation.
    i'm sorry for terminology
    thanks.
    Split Croatia
    57
    6,151
    36
    Re: Oil Accumulation
    Quote Originally Posted by ozankalkan View Post
    hi everyone!
    thanks.
    Hi, ozankalkan. Welcome to RE.
    By carefully designing system and maybe using oil separator.
    Describe little more your problem and system layout.
    Jul 2007
    Australia
    1,845
    question:
    Is the compressor and evaporator on the same level?
    Problems normally occur on poorly designed systems or if the evap is below the compressor.
    Refrigeration engineers solve this through careful design, the rest of us use oil separators!
    Feb 2008
    Las Vegas, NV
    67
    330
    Until you give us more information as nike has suggested, Let's assume this is a freezer.
    Take a look at the defrost operation of this unit to verify all is working well. I always like to see a minimum of 4 defrost cycles in a 24 hour period.
    Proper defrost cycles are very important in low temperature applications. Excess frost restricts the airflow and reduces coil loading. This can cause oil to be trapped in the evap possibly causing floodback to the compressor.
    Apr 2001
    79
    5,071
    35
    What type of system are you working on and why do you believe that oil is accumulating in the entry of the evaporator?
    Jan 2008
    turkey
    5
    thanks for your replies.
    well this problem occurs in refrigerators. there is a capillary tube with heat exchanger. capillary and evaporator tubes are jointed by welding. since capillary diameter size is too smaller than the evap tube diameter, the oil accumulates while flowing into the evaporator tube.
    by the way compressor is below the evaporator, not on the same level.
    how should i design the system? and what is the oil separator?
    thanks again and again.
    Apr 2001
    79
    5,071
    35
    question:
    Even the best separators allow some small amount of oil to pass, so eventually it ends up where it shouldn't be... and this brings us back to careful design.
    Apr 2001
    79
    5,071
    35
    Why do you believe that oil is accumulating? What are the symptoms?
    Jan 2008
    turkey
    5
    This is what have been told to me by some experienced engineers. they also told me that they hear some oilish sound while refrigerant is flowing into evaporator.
    Jan 2008
    turkey
    5
    img91.imageshack.us/my.php?image=oilxd8.jpg
    well this is what i try to tell
    Jul 2007
    Australia
    1,845
    Even the best compressor fitted with separators sometime seize up, I seem them and read about them all the time.
    Ohh shi..
    Seriously, it was a light hearted response because not much information was given
    Forgive me, I shouldn't have. This is serious business, but it's 11.45pm here and not much to do
    Sorry ozankalkan, at least I got you to tell us whether the compressor and evap where on the same level or not and find out whether you know what an oil separator is.
    edit: this is his image from the above post. Saves people copy and pasting as I can hot link so I hope it makes it up to you.
    Apr 2001
    79
    5,071
    35
    Those experienced engineers are wrong. Any oil entering the evaporator is swept through the evaporator by the flow of refrigerant. Oil does not accumulate at the evaporator entrance.
    Jan 2008
    turkey
    5
    So why is there a patent which is named "oil separator for evaporator"?
    Apr 2001
    79
    5,071
    35
    Because it is possible for oil to accumulate in other parts of the evaporator, not the entrance.
    Apr 2001
    79
    5,071
    35
    Would it be possible for a few drops of oil to accumulate as shown in the drawing? Yes. Would this affect the operation? No. It would not be enough to make any difference at all. It is not important.
    Feb 2008
    Las Vegas, NV
    67
    330
    I agree with Gary.
    If it's an issue you have trying to have a 100% perfect system then just don't insert the cap tube too far in the evap inlet.
    Split Croatia
    57
    6,151
    36
    Do you maybe know what velocity of refrigerant you have in evaporator and what kind of refrigerant you using? Could you explain evaporator design?
    Where is refrigerant injection, at top of evaporator or at bottom?
    Do you have parallel circuits or serial circuits in evaporator?
    3,853
    What problem is the oil accumilation at the entry to the evaporator causing? What are the symptoms?
    Is the capiliary blocking up?
    Cheers Jon
  1. oil sludge accumulation in R-22 rack compressor?
    By beachfronttech in forum Supermarket Refrigeration
    Last Post: 04-01-2008, 06:38 AM
