Results 1 to 30 of 30
Threaded View
14-10-2010, 11:05 PM #22
Re: Nice animation of refrigeration cycle
Yes and no.
There are different ways of delivering oil to the comp.
If it is directly delivered then the differential pressure need only be 1 bar and it would still flow the oil. Pressure always flows from high to low.
Some more complex systems restrict the pressure through regulating valves and these are set to be about 5 bar above crank pressure.
There are other ways but the pressure will always be higher in the discharge.
coolrunnings
advanced refrigeration technology
By Lc_shi in forum FundamentalsReplies: 10Last Post: 16-02-2011, 05:22 PM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM -
typical refrigeration cycle
By Lc_shi in forum FundamentalsReplies: 20Last Post: 25-04-2006, 03:45 PM -
closed cycle air refrigeration
By shogun7 in forum RefrigerantsReplies: 56Last Post: 03-03-2004, 08:17 PM
