Results 1 to 30 of 30
    Split Croatia
    6,175
    Nice animation of refrigeration cycle
    http://www.hvacprotech.org/toc/reefer_cycle.html
    Thanks to Hvacprotech member/moderator Gonefishing for leaving this open to general public.
    Mar 2006
    Lancashire
    1,876
    28
    Re: Nice animation of refrigeration cycle
    Great animation, cheers Nike.
    Marc
    Jan 2008
    Australia
    71
    Good One !!!
    Dec 2005
    Zagreb
    191
    Talking Re: Nice animation of refrigeration cycle
    Well done.
    RR
    vejai's Avatar
    vejai Guest
    nice animation
    Feb 2008
    scotland
    wow nice one nike , good on ya
    Ukraine
    Thanks, very nice
    Mar 2007
    Liverpool
    cool animation! (sorry about the pun).
    Jun 2007
    London
    38
    yh that is by far the best system animation ive seen, nice find nike
    64
    triskelionblood's Avatar
    triskelionblood Guest
    very nice indeed.. can i use it for my presentation? if so, how can i download it? thanks...
    Aug 2008
    malaysia
    thanks for sharing ...i like it so much..
    Mar 2009
    KZN, South Africa
    63
    2,212
    Very nice...
    Split Croatia
    6,175
    Quote Originally Posted by triskelionblood View Post
    Here is download link:
    http://www.mediafire.com/?367q0wz6642y89i
    You need Flash file capable player (GOM media player etc..) or you could play it in your browser (Firefox, IE etc...).
    Regarding copyrights, I did not found any information on that.
    Apr 2008
    phillippines
    125
    Very nice presentation on the basic refrigeration cycle.many thanks.it help a lot on those who are a starter on this field.
    abet
    May 2010
    ireland
    im a starter in this field and it has helped so much.thank you
    Split Croatia
    6,175
    If you like it, go here!
    Apr 2005
    Manchester England
    43
    332
    great animation nike thank u.
    quick question the oil seperator just after the compressors how does the oil get back to the compressor crank case?
    cheers lee
    Split Croatia
    6,175
    Quote Originally Posted by moondawn View Post
    cheers lee
    Pressure differential.
    Apr 2005
    Manchester England
    43
    332
    hi nike do you mean that it will be pushed round the system with the refrigerant by pressure?
    Feb 2010
    59
    243
    If the pressure in the discharge is 18 barG then the
    oil in the seperator is 18 barG. The oil in the comp crank case is at, say 3 barG so that means there is a
    pressure differential of 15 bar. That pressure will push the oil to the comp.
    All the best
    coolrunnings
    Apr 2005
    Manchester England
    43
    332
    hi there thanks for the reply, thank u i inderstand it better now so a low hp would hinder the chances of oil returning to the compressor as the differential pressure would become lower?
    thanks for the replies guys
    Feb 2010
    59
    243
    Yes and no.
    There are different ways of delivering oil to the comp.
    If it is directly delivered then the differential pressure need only be 1 bar and it would still flow the oil. Pressure always flows from high to low.
    Some more complex systems restrict the pressure through regulating valves and these are set to be about 5 bar above crank pressure.
    There are other ways but the pressure will always be higher in the discharge.
    coolrunnings
  23. #23
    Apr 2005
    Manchester England
    43
    332
    thanks for the post and explanation coolrunnings
  24. #24
    Mar 2010
    Bangladesh
    40
    151
    nice one boss
  25. #25
    Jun 2009
    North East England
    714
    nice one ..............
  26. #26
    JUNDEP's Avatar
    JUNDEP Guest
    Thanks! Nice animation of refrigeration cycle.
    I would like to copy it for my refrigeration engineering class power point presentation.
    The classroom is not equipped with Real Player and could not download to my desk top computer.
    Kindly help me what to do to copy animation for my power point slide presentation.
    More power to you!
    JUNDEP
  27. #27
    Split Croatia
    6,175
    Quote Originally Posted by JUNDEP View Post
    More power to you!
    JUNDEP
    http://www.refrigeration-engineer.co...5&postcount=13
    http://www.gomlab.com/eng/GMP_download.html
  28. #28
    Jun 2010
    Africa
    28
    Thank u. this is bridging the gap between the diagrams in the books & the real one.
    Sonic
  29. #29
    abeon_elavungal's Avatar
    abeon_elavungal Guest
    very thanks ,it will help me to explain cycle to trainees
  30. #30
    Oct 2010
    MALTA
    9
    ....well done and very interesting,thanks a lot nike!.
  1. Replies: 12
  2. advanced refrigeration technology
    Last Post: 16-02-2011, 06:22 PM
  3. TK basic micro-p features and functions
    By REEFER-TEK in forum Transport
    Last Post: 05-12-2007, 07:25 PM
  4. typical refrigeration cycle
    Last Post: 25-04-2006, 03:45 PM
  5. closed cycle air refrigeration
    By shogun7 in forum Refrigerants
    Last Post: 03-03-2004, 09:17 PM
