Results 1 to 19 of 19
    abd.koj's Avatar
    abd.koj Guest
    Eliwell id974 with lost password and locked keyboard
    hello every body,
    I have a freezer with Eliwell id974 temperature controller, It was locked ,so i can't change parameters because the password was lost,
    how can i open the program ?
    Split Croatia
    6,151
    Re: Eliwell id974 with lost password and locked keyboard
    You need copy card or Elliwell software and interface. Copy card is programed by other free instrument or by Elliwell software and interface, and than copied to your protected instrument by copy card or by computer and interface.
    abd.koj's Avatar
    abd.koj Guest
    Thank you nike123,
    Good idea;
    But how can i get Elliwell software and interface or Copy card?
    Split Croatia
    6,151
    Order from Elliwell (Invensys)
    http://tinyurl.com/ypg5yv
    AivarsB's Avatar
    AivarsB Guest
    password is 10
    4,713
    Quote Originally Posted by abd.koj View Post
    hello every body,
    ABD Please open the attached pdf.
    It explains how to lock and unlock the keyboard.
    Also there is a section about the program passwords etc.
    Open the attached and all will be revealed
    Sep 2003
    ISRAEL
    72
    4,248
    If you are in a hurry, replace the controller
    Chemi
    Martin Smanka's Avatar
    Martin Smanka Guest
    Please send to me also, thank you.
    4,713
    Quote Originally Posted by Martin Smanka View Post
    Martin check the attached on my post above.
    Martin Smanka Guest
    Thank you, but how can i open the menu, when i don't know the password? It is possible? Some universal password or something else?
    Feb 2006
    derbyshire
    610
    change the controller, 10 minute job.by the time you have done messing about with it may end up cheaper.
    4,713
    Read it!
    It tells you how to access the relevant section and the required password.
    Jul 2007
    Czech
    61
    374
    Hi Martin, your JDK Nymburk, will help you
    Jul 2007
    Czech
    61
    374
    Try 321?
    4,713
    Read it!
    Hey Martin.
    Misread what I posred myself.
    Check out Josef's reply.
    I will try and post more tonight.
    When back from Work.
    Jul 2007
    Czech
    61
    374
    Grizzly, password I go to another forum, but not confirmed, and answers a few members
    cuepower64's Avatar
    cuepower64 Guest
    To unlock and reset an ID974:
    1)Push and hold the set key
    2) When PA1 shows scroll to 135 which is the master password
    3) Then enter DIS folder and then sub folder PA1
    4) Enter your new password ( make a note of it) and then push set
    5) If you want to unlock the keypad ...still in the DIS folder scroll to sub folder LOC and set to n.
    That should do the trick.... I know this works as I had to carry out this procedure yesterday.
    Good luck!!
    Feb 2009
    ukraine
    5
    Password 135 opens device id 974
    Mar 2009
    ireland
    87
    this is a top secret but the over riding password on th id range is.........135 dont tell any one
