Thread: Fujitsu a/c
    Feb 2001
    Doncaster, England
    199
    Question Fujitsu a/c
    I have acquired a Fujitsu a/c, indoor model number ASY12RGF-W and outdoor model number AOY12RGSF.
    However there is no wiring information with it.
    What I want to know is how to wire the indoor to the outdoor, and where to wire power to, i.e. which terminals.
    Both indoor and outdoor have terminals marked 1,2,3 and 4.
    Can anybody help please?
    Tony
    Oct 2001
    Nottingham UK
    5,668
    Sure can Tony only the information you need is in the office - from memory
    1 is live
    2 is neutral
    3 is compressor signal
    4 is reversing valve
    will post tomorrow with the proper info
    frank
    Feb 2001
    Doncaster, England
    199
    Thanks for the info so far frank, if you could post proper info I would be grateful.
    Tony
    Jun 2002
    628
    23
    Smile fujitsu a/c
    hi tony and frank
    To elaborate on franks infothe interconnecting wiring for ASY 7/9/12/14/17.
    1)neutral.
    2)compressor control .
    3)solenoid/4way valve.
    4)condenser fan motor.
    The ASY denotes its a wall mount,and if i remember correctly,the power supply is fed to the inside unit (AHU),then outside via a five core ie four cores and earth.Or fed vice versa.
    hope this helps
    regards mark
    Sep 2003
    ISRAEL
    72
    4,248
    hi mark,
    the best way to avoid any mistakes with split air-conditioners, always follow the numbers, they have to be the same inside and out.
    we have here one large manufacturer that uses 9!!! wires- three speed outside fan, contactors, heatpump and control for inside fan for automatic defrost.
    I find it easier to remember colours.
    chemi
    Jun 2002
    628
    23
    Smile fujitsu a/c
    ok ..............
  1. your opinons on fujitsu please
    By acgibo in forum Air Conditioning
    Last Post: 26-08-2009, 05:06 PM
  2. desperately seeking fujitsu
    By rbartlett in forum Air Conditioning
    Last Post: 04-08-2007, 09:06 PM
  3. Fujitsu
    By Abe in forum Air Conditioning
    Last Post: 21-07-2006, 08:36 AM
  4. Fujitsu Password
    By sigorst in forum Air Conditioning
    Last Post: 02-01-2006, 09:56 PM
  5. Fujitsu hp's icing
    Last Post: 08-01-2005, 09:36 AM
