Results 1 to 15 of 15
Thread: Flushing Systems.
17-03-2008, 03:56 PM #1
Flushing Systems.
What is the best product to use to flush a vapor compression system after burnout or for flushing a system to retrofit from R12 to R134a?
Is there a cheap, safe product for doing this that won't hurt the compressor or affect polymer oils?
Please no one recommend R11
17-03-2008, 04:24 PM #2
Re: Flushing Systems.
I have great success with Isopropyle alcohol as a flushing agent.
17-03-2008, 05:19 PM #3
Isopropyle alcohol? Can you use this to flush out the compressor as well?
Thanks MG Pony.
17-03-2008, 05:26 PM #4
I've don it with compressors with no signs of degradation, I'd try it with a junked one and meg it after to make sure.
24-03-2008, 01:01 PM #5
dry nitrogen can be used it is cheaper too
24-03-2008, 01:36 PM #6
Nitrogen is the best
24-03-2008, 02:35 PM #7
best stuff I have used is a product called fenseclean from a company called fense chemicals (dutch I think). It reduced mineral oil content down to a proven 0.1 %
24-03-2008, 02:54 PM #8
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
24-03-2008, 03:24 PM #9
24-03-2008, 05:06 PM #10
Well dry nitrogen after some iso is thee best
25-03-2008, 11:16 AM #11
25-03-2008, 11:27 AM #12
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Do you used this:
http://www.fens.nl/index.php?id=30
What is your procedure and tools for flushing?
25-03-2008, 11:43 AM #13
A flushing machine from polar pumps , it is basicaly a pump which circulates the fluid arond the system by replacing the compressor it has a refrigerated on board storage tank to prevent the fluid evaporating/ gassing off and a purge facility to enable the fluid to be remove from the system when its been flushed it cost about £3500.00 but they would come to your site and do it for you if you only have one system that needs flushing
25-03-2008, 12:00 PM #14
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
25-03-2008, 12:17 PM #15
Co2 Systems in Supermarkets
By 750 Valve in forum Supermarket RefrigerationReplies: 22Last Post: 19-10-2007, 08:51 AM -
Flushing Agent
By dallas in forum FundamentalsReplies: 4Last Post: 11-07-2007, 11:31 PM -
My local Apprentice Training Classes
By shogun7 in forum TrainingReplies: 12Last Post: 17-03-2007, 03:10 PM -
HFCs for flooded systems?
By garyb in forum RefrigerantsReplies: 15Last Post: 21-04-2006, 10:02 PM
