Results 1 to 18 of 18
    india
    47
    7
    Thumbs up Frequent compressor burn outs
    Dear guys,
    Best Wishes for all of you.
    For the past 5 years i am facing the frequent compressor failures kindly suggest me to over come this failures.
    Attached Files Attached Files
    Split Croatia
    57
    6,151
    36
    Re: Frequent compressor burn outs
    What are the conditions with power supply. Burn out are in lot of cases connected with bad power supply.
    india
    47
    7
    The power supply is stable. ie 400V (+/- 5 v of variation) and the power failures is twice a week only.
    Feb 2008
    Las Vegas, NV
    67
    330
    Quote Originally Posted by askannan View Post
    Twice a week is a lot! Do these compressors have any sort of phase line monitors or surge protection devices installed?
    Nov 2006
    63
    392
    Are you cleaning the system after the burn out, have you checked for acid in the system?
    If not there is your problem.
    Ian
    Split Croatia
    57
    6,151
    36
    Twice a week! You certainly need good under voltage and phase loss/rotation protection.
    Also, after change of compressor, did you fitted acid filters and controlled oil acidity, and change them in to normal filter after you assured that there is no acid in oil any more?
    Did you checked and changed contactor when you changed compressor?
    11,025
    Word .doc from Askanan
    One of my customer having 300TR x 6nos of Screw chiller. The chiller package consists of 2 Nos vertical hermetic screw compressor. It has to maintain the chilled water temperature of 44 deg. F at ambient temperature of 105deg.F (max). One chiller package having two independent refrigerant circuit (case cade system). This is a flooded type chiller with air-cooled condenser (with fan staging control).
    I am maintaining the discharge super heat below 50deg.F by using the liquid injection. The compressor dose not reach it’s RLA at any circumstances even though these compressors are failing frequently.
    If any one came across this kind of problem kindly tell me what could be the problem. Kindly suggest me what kind of precaution to be taken to avoid this kind of problems.
    Aug 2005
    5,302
    Repeated burnouts on the same system is either due to one or two things.
    Either system is not being cleaned out good or the electrical power is terrible. This sounds like a Dunham-Bush screw chiller and it should have phase loss/reversal protection already.
    As nike123 pointed out you should also check the contactor. I have seen some where the power supply was OK on the line side of the contactor, but when energized the load side voltage variation was not good (contacts were burnt from arcing).
    Is this the total variation or only between two phases?
    india
    47
    7
    Quote Originally Posted by powell View Post
    There is Power Control Relay in the circuit which is taking care of phase reversal/ unbalance, phase failures and over /under voltage. Ther is no surge protection device in the system.
    india
    47
    7
    india
    47
    7
    It is the total variation
    india
    47
    7
    Before fix the new compressor into the burnout system we do throuh clean of the system by usig Trichloro ethylene. after that flush out the system with dry nitrogen. De-hydrate the system during vaccumizing by using strip heaters on the condenser coils. We replace the catch all drier in the oil return line with high acid / burnout core. After re commissioning the compressor we run the compressore for 12 hours and we do replace the compressor oil and catch all drier core. we use fresh refrigerant for this system
    Split Croatia
    57
    6,151
    36
    Did you checked first oil for acidity after replacing it with new one.
    Did you checked new oil after some time for acidity?
    Did you changed/checked contactor?
    Split Croatia
    57
    6,151
    36
    What make and model is that power control relay?
    Apr 2008
    Harrisonburg, Va.
    Don't rule out intermittant flood-back with resulting spikes in amp draw. Those packages had literally no provisions for suction superheat and it was VERY common to experience slugging. Hard to beliveve, but early versions (without automated liquid metering valving) were critically charged and if you over-charged them just a bit, slug they would.
    Apr 2006
    India
    I have gone thru your problem statement.
    In the same you have mentioned that you are maintaining superheat less than 50 Deg F which is quite higher.
    Standard superheat setting will be from 15 to 20 Deg F.
    For getting 44degF water temp what is your evap temp or suction pressure? And your discharge pressure?.
    Have you checked the location and operation of TXV bulb for proper superheat?
    Just let me know what are the operating parameters?
    Jul 2001
    Sydney, Australia
    753
    Quote Originally Posted by kbrohit View Post
    He means 50k DISCHARGE superheat - that is the discharge temps are maximum 50K above the saturated condensing temp and he is controlling them with liquid injection.
    Like previously mentioned - have you changed the contactors on any of the comp changes?
    ...and she said "give it to me you big fridgie"
    Oct 2007
    NZ
    85
    Are you sure you are putting compressors for the correct voltage rating back in , or are they wired for the correct voltage , some are star for high voltage and delta for low voltage , I worked on a york chiller a few years ago with dual voltage compressors it had 9 terminals on the compressor and some one got it very wrong .
    also if its part winding start are you getting the sequence right and are both contactors staying in and drawing even amps?
  1. Looking for thermoking genset take outs.
    By RaFelix in forum Commercial
    Last Post: 22-07-2008, 02:04 AM
  2. Reasons for High Pressure / Low Pressure Trip outs
    By majikman in forum Air Conditioning
    Last Post: 02-02-2007, 08:47 PM
  3. Frequent Failures
    By abdulazman in forum Trouble Shooting
    Last Post: 08-01-2006, 07:40 PM
  4. Motor burn outs
    By bernard in forum Industrial Compressors
    Last Post: 25-06-2005, 11:00 PM
