Results 1 to 10 of 10
    Oct 2005
    Romania
    44
    water source heat pump
    Hello
    I want to design an HVAC sistem for office building with water source heat pump . Please help me with some informations about this system .
    Gramcor
    Feb 2007
    2,473
    45
    Re: water source heat pump
    If you have a Mitsubishi Electric distributor in Romania then they are doing a purpose made VRF for just this application.
    Aug 2007
    Sydney
    52
    1,083
    23
    What is the heat source?How much is the load?How much waste heat con you recycle? From Where?
    Feb 2008
    Sudan
    89
    You can use DAIKIN VRV system it is very good for this purpose
    Oct 2005
    Romania
    44
    Quote Originally Posted by Tesla View Post
    I have 250 sqm sandard office area on each level ( 5 level high ), about 150 000 Btu/h on each level .
    How must design the system structure ? I put on each level water source heat pump , but how must calculate the cooling tower and heating system for water source ?
    I do not have geotermal water source . Please help me with some informations in this directions.
    Gramcor
    Hereford
    65
    8
    The Denco "Officecool" system zone units are available as water source heat pumps. Try looking at their website.
    There is a distributor in Romania called Aer Tech.
    Alaska USA
    71
    10
    Quote Originally Posted by gramcor View Post
    Gramcor
    If, you don't have cheap heat source such as warm waste water or large body of water nearby, it'll not make any better than using boiler to heat up building.
    tedre
    Oct 2005
    Romania
    44
    Quote Originally Posted by tedre View Post
    tedre
    Thanks , Tedre
    I have a lake nearest building but in Romania is necessare to obtain approval to use natural water for heatpump . ( Is normal , because i change natural temperature of water....)
    Gramcor
    Feb 2008
    Sudan
    89
    Gramcor
    You must select your system according to :
    1- Your requirments.
    2- Availability.
    3- cost.
    then you can calculate the cooling tower and heating system for water source according to the energy rejected from your outdoor units.
    As example if you used Daikin VRV-WII water cooled system the manufacture will give you all data you need to select your cooling tower or boiler.If you used the heat pump mode the units can give you cooling only or heating only (you can change),But if you used the heat recovary mode the units can give you cooling and heating at the same time.
    So make your dissection.
    Aug 2008
    Englewood, CO
    23
    This project is too big for "on the job training". There are many pitfalls. Let an engineering design firm take over. It is best not to stain your reputation with a bad job. Other opportunities will present themselves.
  1. frostles heat pump
  2. Evaporator Design-Air Source Heat Pump for water heating
    By anup in forum Technical Discussions
    Last Post: 20-03-2006, 02:26 PM
  3. water source heat pump
    Last Post: 29-03-2005, 09:09 PM
  4. Building a wine cabinet
  5. Mcquay water source heat pump
    By bernie in forum Air Conditioning
    Last Post: 10-02-2003, 01:53 AM
