Thread: Cold room sheet metal supplier
16-03-2008, 03:06 PM #1
I have a requirement to 're-skin' the interior of a small cold room. I am trying to find a manufacturer of panels that would be able to provide coated sheet metal cut to size to enable me to do thi .
if anyone knows of such a company it would be great.
16-03-2008, 03:40 PM #2
Re: Cold room sheet metal supplier
Matt
Checkout British Steel or as they are now called Corus I think?
Anyway the material you need is called "plastisol".
Or "steelvatite".
Just search their site for local suppliers.
Good Luck
16-03-2008, 03:47 PM #3
Would it not be easier and cheaper to rip out and start again?
What about the condition of the floor?
16-03-2008, 04:39 PM #4
try Gary at G R Scotts
they are in ossett west yorkshire
17-03-2008, 01:00 AM #5
Does it have to be steel, can you use 'plastic' sheeting?
17-03-2008, 07:39 AM #6
is there a corrugation on the skins? Then Often the Removal of the sheets means you are taking out the foam pieces as well.
But you can try out DC Systems Denmark as they are suppliers of the panels & can get you the sheets you need. In case you are really serious, send me PMS & I can talk to them.Send me more details.
17-03-2008, 10:17 AM #7
I recomend to ask for Alum whole saller in your area. ask for the Alum checkered plate and this one came with 4 x 8 ' I think which is very good and strong as well , take the one with 2 mm thickness.
And good lock
Khalid
Insulation for Cold Room
By tjk2007 in forum FundamentalsReplies: 25Last Post: 19-03-2010, 02:54 AM -
Cold room floor
By Andy AC in forum CommercialReplies: 8Last Post: 19-02-2009, 04:26 PM -
cold room
By CHILLED4 in forum Trouble ShootingReplies: 5Last Post: 16-11-2007, 11:44 PM -
Installation of cold room
By Josip in forum Legal-Business-MarketingReplies: 12Last Post: 12-03-2006, 09:20 PM
