Thread: Unit coolers using glycol
15-03-2008, 10:23 AM #1
Dear All,
I need some details to my design.
Plant : Vegetables.
Refrigerant Ammonia
Secondary Coolant:38% Prop. Glycol.
The temp.for the rooms are as follows.
Raw Goods Vegtables Mixed: 4ºC
Cleaning & Sorting 4ºC
Processing 15ºC
Cleaning of dirty crates 22ºC
Finished Goods 0ºC
The above said are customer requirements. We cannot change.
Basically I consider the Room temp 0ºC and take the glycol temp. as follows
Temp in to the unit coolers: -14ºC
Temp Out from the unit coolers:-7ºC
My Question is
- Is it possible to attain the room temp 22ºC in the same temperature program.
- If not what is the solution for that.
Hope I will get some details.
Regards,
TJK
16-03-2008, 12:33 AM #2
Re: Unit coolers using glycol
My Question is- Is it possible to attain the room temp 22ºC in the same temperature program.
What is the ambient air temperature in your region? Can ambient air be used for heating?Brian - Newton Abbot, Devon, UK
16-03-2008, 03:06 AM #3
Remember Relative Humidity is important. The same should be 80 to 85%.
23-03-2008, 07:49 AM #4
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM -
Thermo King OptiSet
By REEFER-TEK in forum TransportReplies: 4Last Post: 06-12-2007, 07:23 PM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM -
Brands unit coolers USA?
By Friobernal in forum Technical DiscussionsReplies: 6Last Post: 06-08-2003, 08:35 PM
