Results 1 to 11 of 11
    khuong's Avatar
    khuong Guest
    Unhappy Re: Question about Capillary
    thank you very much! I have a question about capillary tube. I want to get more information about it. Can you help me?
    Apr 2006
    41
    1,620
    it's a tiny tube that comes in differant sizes, and is made of copper?
    with out a bit more detail thats about all I can give ya!
    Split Croatia
    57
    6,151
    36
    11,025
    Excellent link Nike, thanks I might have to use it myself sometimes.
    Nov 2007
    London
    461
    the length and bore is very important..
    Jan 2008
    Kent UK
    49
    514
    Thanks Nike it was a very usefull link
    If it ain't broke, it doesn't have enough features yet.
    Damo
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by chunky munkey View Post
    I am sure that it will be very beneficial in many cases.
    Mar 2008
    Ohio
    You can also look up Heat Pipe
    Oct 2005
    In a 2 bedroom unit. Why's That? :)
    314
    Capillary action, capillarity, capillary motion, or wicking is the ability of a substance to draw another substance into it. The standard reference is to a tube in plants but can be seen readily with porous paper. It occurs when the adhesive intermolecular forces between the liquid and a substance are stronger than the cohesive intermolecular forces inside the liquid. The effect causes a concave meniscus to form where the substance is touching a vertical surface. The same effect is what causes porous materials such as sponges to soak up liquids.
    A common apparatus used to demonstrate capillary action is the capillary tube. When the lower end of a vertical glass tube is placed in a liquid such as water, a concave meniscus forms. Surface tension pulls the liquid column up until there is a sufficient mass of liquid for gravitational forces to overcome the intermolecular forces. The weight of the liquid column is proportional to the square of the tube's diameter, but the contact length (around the edge) between the liquid and the tube is proportional only to the diameter of the tube, so a narrow tube will draw a liquid column higher than a wide tube. For example, a glass capillary tube 0.5 mm in diameter will lift approximately a 2.8 mm column of water.
    With some pairs of materials, such as mercury and glass, the interatomic forces within the liquid exceed those between the solid and the liquid, so a convex meniscus forms and capillary action works in reverse.
    Apr 2006
    41
    1,620
    Quote Originally Posted by scrapen View Post
    Uhm NO, thats simple shortest answer.
    May 2003
    uk
    9
    used as a metering device for refrigeration systems. controls the superheat, discharge superheat of compressors and also governs the performance of a system. very hit and miss. Cant just be changed to get more cooling performance by just the length, the internal bore is also very important.
  1. Distributor & Capillary tube position
    By MrReds in forum Technical Discussions
    Last Post: 29-03-2008, 07:40 AM
  2. :rolleyes: capillary tube size in distributor?
    By abbasi in forum New Technologies
    Last Post: 08-07-2006, 03:56 PM
  3. metric capillary tube
    By tralex in forum Fundamentals
    Last Post: 21-02-2006, 06:57 AM
  4. Replies: 15
    Last Post: 24-10-2002, 06:52 PM
