Thread: water chiller question
12-03-2008, 09:31 AM #1
I have a question about water chillers.
I want to build up a 7Kw water chiller.
I am building a small water tank with glycol, the glycol will be cooled by a brazed plate heat exchanger using refrigerant as the primary cooling.
In that tank I want to run a length of 3/8" copper pipe in that tank to cool down water running to another application.
Does anyone have information on how to work out the total length of pipe i will need
12-03-2008, 09:41 AM #2
Re: water chiller question
You are going to have to provide a lot more information before any calculations can be done, such as:
What are the expected cooling water entering and leaving temps (T1, T2)
How big is the load you are cooling
What temp is the refrigerant evaporating at
How much water is in the tank
What concentration is the glycol
What will the primary circuit flow rate be in kg/s
What will the secondary flow rate be in kg/s
etc
12-03-2008, 09:21 PM #3
If you are into a bit of calculation then you could start here...
http://en.wikipedia.org/wiki/Heat_transfer_coefficient
also
http://www.eng-tips.com/viewthread.c...=171100&page=1Brian - Newton Abbot, Devon, UK
Water Chiller
By lana in forum Technical SpeculationsReplies: 20Last Post: 23-06-2007, 01:19 AM -
Water chiller help
By ultralo1 in forum Trouble ShootingReplies: 6Last Post: 12-05-2007, 11:52 AM -
Connecting Trane Water chiller to air handling unit
By celtictech in forum FundamentalsReplies: 10Last Post: 08-03-2007, 06:14 PM -
Water Chiller Control
By David PS in forum Air ConditioningReplies: 4Last Post: 29-08-2006, 11:14 PM -
Building a wine cabinet
