    Mar 2008
    Midlands
    48
    1
    oil free compressor
    I have been commissioning a chiller with a new turbocor compressor today.
    Oil free compressor on magnetic bearings.
    very impressive!
    Any one else had much experiance on these yet?
    11,025
    Re: oil free compressor
    Doing a quick search on this forum shows a recent thread on the subject...
    http://www.refrigeration-engineer.co...light=turbocor
    Nov 2007
    Czech Republic
    43
    8
    I heard , Last year in Italy exhibition there was a lot of exhibitors with turbocor, now only one company.
    Whats happenned? Does it work correctly?
    Jul 2004
    Netherlands/Germany
    61
    8
    Axima refrigeration in Germany they can tell you all about the turbocor
    Feb 2007
    55
    These compressors are of centrifugal design and as such are more useful for high capacity water cooled chillers.There are however several manufacturers such as RC Group,Climaveneta usin them in Air-Cooled applications.There has been some success in the USA using them in retrofit solutions.I tested two of these compressors some years ago now on a R134A industrial type water cooled units and found them very good up to around 42-45 C condensing temperatures.Therefore I believe the application transition into Air-cooled is quite difficult because the condensing temperatures are up in the 53 C + area.Being of centrifugal design they are susceptible to surge conditions as well as being restricted at low loads which as I said makes them good for high capacity where the turndown is equal to say one compressor running.Start up current are low circa 2Amps,they have an impressive control strategy of their own however this makes it complicated to apply to chillers due to controls compatability.The oil free side is good no loss of performance in heat exchangers and no lubrication system to consider in the design process.Overall a very good technology but very expensive and limited in application.
    Hope this helps.
  1. Compressor loading, cooling, and range of operation.
  2. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
  3. Mitsubishi compressor lock
    By marc5180 in forum Air Conditioning
    Last Post: 08-10-2007, 05:48 PM
  4. oil free compressor
    Last Post: 22-10-2006, 01:28 PM
  5. Compressor pumping efficiency
    By shogun7 in forum Fundamentals
    Last Post: 25-02-2004, 10:50 PM
