Results 1 to 1 of 1
04-03-2008, 01:14 AM #1
Question on EER & Low Capacity Scrolls
Hello,
Just two quick questions for you experienced folks;
For a high temp compressor the EER is rated at a standard evap/cond temperature of 45F/???
I found the medium temps to be rated at 20/120F....
Another question: are lower capacity scroll compressors (1/3HP) generally less efficient (both isentropic & EER) than their more powerful siblings? I found the EER of a 1/3HP scroll to be 6.4, whereas the 1HP was closer to 10. Is this normal?
Thanks for your help
Patrick
capacity question
By dannycool in forum Air ConditioningReplies: 1Last Post: 26-08-2006, 05:15 PM -
R-407C and Coil Capacity
By glabah in forum RefrigerantsReplies: 5Last Post: 03-06-2006, 11:36 AM -
Capacity achievement
By Hemant Anand in forum IndustrialReplies: 8Last Post: 18-12-2005, 01:18 AM -
New Capacity Control Solution
By embrown in forum New TechnologiesReplies: 19Last Post: 30-12-2003, 01:33 PM -
TEV capacity related to pressure drop
By DaBit in forum CPU OverclockersReplies: 8Last Post: 06-12-2002, 05:11 PM
