Thread: problems,problems...
03-03-2008, 08:11 PM #1
if any one can help me with this please do ....
upright fridge r134a suction pressure 30 psi is that ok .as you can see i`m very new in subject.whot about 404 freezer if i will look at suction gage 1 bar for upright freezer is that ok.how mutch bellow zero do i need to look on suction line on normal run of unit if i would achive -25 .thanksLast edited by przemo2; 03-03-2008 at 08:13 PM.
03-03-2008, 10:34 PM #2
Re: problems,problems...
przemo2, you're asking for help on a fridge running on 134A. Fair enough, you might be a DIY guy. But you are also asking about systems running on 404A. This is not common in the domestic market.
You wouldn't be trying to fix a freezer in your mates snack bar now would you. Without proper knowledge, saturation charts and therfore without proper training, insurance, tools, certificates...ect Don't burn your fingers pal cos if the ***** doesn't the fines will!
04-03-2008, 08:39 AM #3
04-03-2008, 03:33 PM #4
Przemo2,if you've got your gauges connected to the system,you should just be able to read the temperature from there,and always have you thermometer handy too.If you have a P-T Chart handy,it would help.If there is nothing else wrong with your system,you should be fine....
