Thread: Molecule size?
    Split Croatia
    6,151
    Molecule size?
    Does anyone know what is difference in molecule size between R22 and gases composing R410a? I heard/read somewhere that R410a has components that have molecule size smaller by 20 times than R22.
    11,025
    Re: Molecule size?
    I can give you the molecular weight of each but can't explain what it means, sorry..
    R22 86.48
    R410a 72.6
    (Made up of R32 79.2 and R125 120.02)
    Data from
    http://encyclopedia.airliquide.com/E...D28=81&RD29=82
    Jan 2008
    Kent UK
    49
    514
    Re: Molecule size?
    Hi Nike123
    http://www.arkema-inc.com/literature/pdf/632.pdf
    technical data on r22 r407 r410 you probably know all this anyway
    Chunk.
    If it ain't broke, it doesn't have enough features yet.
    Damo
    Jun 2005
    California
    394
    Re: Molecule size?
    nike123, I only found the weight
    R410A Molecular weight: 72.58
    R22 Molecular weight: 86.47
    Jan 2008
    Kent UK
    49
    514
    Re: Molecule size?
    Its the r32 in it that makes r410 have smaller molecules thus is why pipes and fittings must be stronger.
    http://www.allchemi.com/eng/refreger...ternative.html
    Half way down is r125 and r32 at the bottom of page.
    Damo
    Split Croatia
    6,151
    Re: Molecule size?
    Ok guys, keep digging, we coming to something!
    11,025
    Re: Molecule size?
    As an aside to this, one thing with the R32 is that because it's molecular size is smaller than water is why the filter driers had to be redesigned.
    The R32 would fill them up, leave no room for moisture and block the line.
    3,856
    Re: Molecule size?
    I've always though its a bit like sand and gravel, the idea the the hfc refrigerants leak more than the old cfc/hcfc ones. If it is coming out one molecule at a time, no need to worry, unless its an o ring or such when one at a time over the whole o ring would add up. Most leaks are more like sand or gravel being tipped out of a truck, the size of the molecules or aggregate makes no odds as the hole is so big in relation to them.
    But ive been wrong before...
    Jon
  1. Duct Size Calculations
    By hamidpia in forum Tools and Calculators
    Last Post: 21-06-2010, 01:56 PM
  2. Humidifiers with 1 micron droplet size
    By sharshal in forum Technical Discussions
    Last Post: 11-05-2007, 07:35 PM
  3. Evaporator design: minimal channel size.
    By DaBit in forum CPU Overclockers
    Last Post: 05-06-2003, 03:47 PM
  4. Urgent!!! S.O.S. - nozzle size
    By herefishy in forum Fundamentals
    Last Post: 25-05-2002, 10:29 PM
