Results 1 to 8 of 8
Thread: Molecule size?
02-03-2008, 10:03 PM #1
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Molecule size?
Does anyone know what is difference in molecule size between R22 and gases composing R410a? I heard/read somewhere that R410a has components that have molecule size smaller by 20 times than R22.
02-03-2008, 11:03 PM #2
Re: Molecule size?
I can give you the molecular weight of each but can't explain what it means, sorry..
R22 86.48
R410a 72.6
(Made up of R32 79.2 and R125 120.02)
Data from
http://encyclopedia.airliquide.com/E...D28=81&RD29=82Brian - Newton Abbot, Devon, UK
02-03-2008, 11:20 PM #3
Re: Molecule size?
Hi Nike123
http://www.arkema-inc.com/literature/pdf/632.pdf
technical data on r22 r407 r410 you probably know all this anyway
Chunk.If it ain't broke, it doesn't have enough features yet.
Damo
02-03-2008, 11:22 PM #4
Re: Molecule size?
nike123, I only found the weight
R410A Molecular weight: 72.58
R22 Molecular weight: 86.47
02-03-2008, 11:34 PM #5
Re: Molecule size?
Its the r32 in it that makes r410 have smaller molecules thus is why pipes and fittings must be stronger.
http://www.allchemi.com/eng/refreger...ternative.html
Half way down is r125 and r32 at the bottom of page.If it ain't broke, it doesn't have enough features yet.
Damo
03-03-2008, 12:22 AM #6
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Molecule size?
Ok guys, keep digging, we coming to something!
03-03-2008, 01:05 AM #7
Re: Molecule size?
As an aside to this, one thing with the R32 is that because it's molecular size is smaller than water is why the filter driers had to be redesigned.
The R32 would fill them up, leave no room for moisture and block the line.Brian - Newton Abbot, Devon, UK
03-03-2008, 01:14 AM #8
Re: Molecule size?
I've always though its a bit like sand and gravel, the idea the the hfc refrigerants leak more than the old cfc/hcfc ones. If it is coming out one molecule at a time, no need to worry, unless its an o ring or such when one at a time over the whole o ring would add up. Most leaks are more like sand or gravel being tipped out of a truck, the size of the molecules or aggregate makes no odds as the hole is so big in relation to them.
But ive been wrong before...
Jon
Duct Size Calculations
By hamidpia in forum Tools and CalculatorsReplies: 17Last Post: 21-06-2010, 01:56 PM -
Humidifiers with 1 micron droplet size
By sharshal in forum Technical DiscussionsReplies: 12Last Post: 11-05-2007, 07:35 PM -
Evaporator design: minimal channel size.
By DaBit in forum CPU OverclockersReplies: 9Last Post: 05-06-2003, 03:47 PM -
Urgent!!! S.O.S. - nozzle size
By herefishy in forum FundamentalsReplies: 3Last Post: 25-05-2002, 10:29 PM
