Thread: Daikin remote thermostat
01-03-2008, 09:50 PM #1
Hello guys, do any of you know whether or not you can get a remote stat kit for a daikin FTY35 wall mount?, which is about 8 year old (R22). I know you could get them for the skyair range but not sure about the little ones. If you can't, can you extend the existing probe?
Andy
01-03-2008, 10:22 PM #2
Re: Daikin remote thermostat
I believe that you still can buy them.
But yes, the built in one can be extended (as long as you use proper cable and connections, no "twisting" together)
Has the unit got a wired controller?
If it does you can tell the unit to use the remote's sensor instead of the built in one....
01-03-2008, 10:25 PM #3
No, it's a hand held zapper remote.
Andy
01-03-2008, 10:29 PM #4
OK,
Back to the first 2 options then
02-03-2008, 12:05 PM #5
Hi Andy
I've successfully extended the cables on sensors using good quality thin 2 core copper cable & connector block. You have to cut the sensor cable & strip back the cables. Then insert the extra cable by twisting the ends together & putting in some terminal block or crimps but you must twist the wires together first. If you solder or use any other method where by the wires are not in contact with each other you'll alter the resistance of the sensor in which case it wont work properly.
Frostycold
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Daikin A/C Cellar Temperature Control
By Cellar Dweller in forum FundamentalsReplies: 15Last Post: 10-01-2008, 11:55 PM -
daikin vrv on/off remote signal trouble
By coriolan in forum Air ConditioningReplies: 7Last Post: 09-06-2007, 11:27 AM -
daikin remote controller setting list
By knight rider in forum Air ConditioningReplies: 9Last Post: 21-05-2007, 10:10 PM -
Remote Control problem
By botrous in forum Air ConditioningReplies: 2Last Post: 12-10-2005, 05:36 PM
