    Feb 2008
    nicholasville kentucky
    daikin how to wire multiple outdoor units together
    can somebody give me a good diagram or methoid on how to wire the outdoor units toghter so you can run them in tandom
    Oct 2001
    Nottingham UK
    5,667
    Re: daikin how to wire multiple outdoor units together
    Just use a 2 wire cable between F1 F2 Outdoor to Outdoor on the external units (assuming you are talking about VRV)
    Feb 2007
    2,473
    45
    First you will need to tell us a bit more...
    For example what Daikin units you are talking about and exactly what you mean with "tandem".
    I assume that you are looking at a VRV system and that you want to establish a master-slave relationship?
    If this is the case then:
    - Control wires from indoor units connects to F1-F2 [indoor-outdoor] on the Master
    - Q1-Q2 [Multi outdoor] on the Master is linked to Q1-Q2 [Multi outdoor] on the Slave.
    That's it, no more cables needed.
    If this isn't what you are trying to achieve, please let us know and we will try to help you.
    Feb 2008
    is there any other commission steps that need to take place
    Feb 2007
    2,473
    45
    That again depends on what you are working on...
    Single split?
    Cooling/heating VRV?
    Heat recovery VRV?
    And what your system(s) actually got connected to them...
    How many indoor units?
    Central control?
    Groups?
    Tell us more and we will be able to assist you more.
    Split Croatia
    57
    6,151
    36
    I am sure that you guys from Kentucky don't have language barrier problem, and if you elaborate little more yours problem we will help you easy.
    Feb 2008
    sorry heat recovery vrv 4 outdoor units with i touch controller i have little to no training so please help the best you can i no enough to be dangerous
  1. Daikin not working... many problems
    By stankovicv in forum Air Conditioning
    Last Post: 11-12-2010, 09:01 AM
  2. Daikin, Why do we bother?
    By gwilliamson in forum Air Conditioning
    Last Post: 02-02-2010, 09:38 AM
  3. Transmission wiring on Daikin VRV2
    By Markie in forum Air Conditioning
    Last Post: 25-09-2009, 06:24 PM
  4. SR2 50 models electric SBY diagonostics made simple
    By absolute-zero in forum Transport
    Last Post: 04-01-2008, 05:11 PM
  5. !!big Daikin Problem!! Codes,u4,pj, And E0
    By airconengineer in forum Air Conditioning
    Last Post: 31-05-2007, 09:04 PM
