Thread: onder
    ondero's Avatar
    ondero Guest
    onder
    Hi everyone !
    1)I need your help.Right now I have been buy a new booster Frick RWF II 856.What do you think about this model ? ( Advantages Disadvantages )
    2) do you have any experiences about desuperheater systems ?
    Regards,
    Aug 2005
    5,302
    Re: onder
    Are you talking about desuperheaters for water or refrigerant (for low stage to high stage compressors)?
    ondero's Avatar
    ondero Guest
    Re: onder
    I want to use Hp compressor discharge gas for water heating with phe
    Aug 2005
    5,302
    Re: onder
    Make sure the PHE is able to drain the liquid refrigerant as it condenses in the heat exchanger. If liquid accumulates in the PHE because it cannot drain properly you will loose the heating capacity of the PHE.
    Dec 2006
    turkey
    8
    Re: onder
    If you contact to frigo mekanik from turkey . be sure they will assist you .
