Results 1 to 23 of 23
    Dec 2004
    Weihai,China
    800
    fresh fruit store issue
    Hi dear sirs
    How to prevent fresh fruit to dehydrate in cold room?
    It's asked by one of my friends but I've no idea about that. Pls help me
    thanks
    LC
    Jan 2008
    Australia
    71
    Re: fresh fruit store issue
    There is a product called Thermfresh that may help. They are here is Aust. but are overseas as well. They are an evaporator which has water jets in it to increase the humidity.
    dsp
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Lc_shi View Post
    Hi dear sirs
    thanks
    LC
    By maintaining humidity in cold room at proper value with humidifier. Also, for preservation of fresh fruits from rapid decay, there must be control of atmosphere inside cold room (control of CO2 concentration).
    May 2006
    India
    82
    1,013
    Hello Lc,
    For the storage of fresh fruits, temperature and humidity are very important. Each fruit has its own requirement and as depending on the fruit the temperature and the humidity is to be set.
    The best way to maintain the humidity is by the Coil. Select a large surface coil with low Td. Generally a Humidity of 80 to 95% RH is required depending on the fruit. This way you will not only attain the required conditions, but also the size of the moisture contents would be so small, that it will not settle down on the fruit and cause chilling injury
    The temperature may be any where between 0 to +4 oC.
    I hope I have been able to answer your question.
    Jul 2006
    THAILAND
    TD / DT1 ; temperature difference controlled ;
    water drain.
    Humidity control : Added/ water
    Co2 C.A.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by mano View Post
    water drain.
    Co2 C.A.
    Hey pal, telegraph era is long time ago passed, now it is allowed to be little more eloquent in long distance communication.
    Aug 2007
    Sydney
    1,083
    23
    Hi Lc Shi
    Another parameter to consider is packaging - enough to alow product to breathe but restrict evaporation
    Dec 2004
    Weihai,China
    800
    i've learned that key points are:
    1. temperature and humidity control
    --- low TD large surface evaoprator + humodifier ?
    2. co2 removal
    ---by ventilation? how to quantify the air volume?
    3. packing --balance the breathe and evaporation
    ---How to do ?
    thanks
    LC
    May 2006
    India
    82
    1,013
    Hello Lc,
    If you select the Evaporator properly and balance the system, no additional humidifiers shall be required for maintaining the Humidity. It is better to do without the humidifiers as they are liable to wet the boxes and damage the fruits.
    As for the breathing, the fruits are packed in perforated boxes. They have these special packing boxes.
    The most important aspect for fruit storage is Temperature and Humidity. If you want more details, you may contact U.C. Davis who are an authority in fruits. They have a Educational University and they share the information. I will try and get the website.
    Mar 2006
    maharashtra
    9
    Hi LC
    For presevation of fruits alone temp and RH maintaining won't be enough. First, one has to understand biology of various fruits. Some fruits are ethylene generator while some are ethylene sensitive. You have to manage ethylene levels. Ethylene is death senesense which destroys green leafy vegetables and many cut flowers.
    You have to scrub ethylene many times to avoid decay in fruits/flowers stored. Ethylene generation is
    less at lower temp.
    Higher level of Co2 and Lower level Of O2 will keep fruit more fresh due to lowest rate of respiration.
    The above is termed as Controlled atmosphere/Modified Atmosphere Rooms ( CA / MA Rooms)
    Your querries will be answered by PM
    Good Bye Sunil Bhat India
    Feb 2008
    Suadi arabia
    7
    Dear all:
    The problem with humidifer that water should be fully vaporized and treated in order to prevent cross contamination, and this is not the case in most facilities. Also in order to have longer storage period and to avoid box collapsing, carton should ba waxed, this is costly
    The use of PM valve is very imposrtant in a DX system to miantain constant DT which has a major impact of the RH. For secondary system, the use of FD is usiful. We developed what is called dry coil high humidity system that has 85-90% RH during the precooling process for grapes and strawberries.
    May 2006
    India
    82
    1,013
    For Food Preservation, Freezing, Pre Cooling etc, it is very important that one has to know more about the product. Refrigeration becomes a secondary feature.
    However the question here is that how to avoid dehydration of the produces while storing them. CA & MA are special application and all fruits will not be required to be stored in such Cold Storages. For example apple storage is more effective when it is a CA Storage, whereas Grape Storage does not require CA.
    Feb 2008
    Suadi arabia
    7
    NO this is not right, CA and MA should be acompanied with refrigeration.
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, aansari
    welcome to RE forums...
    Quote Originally Posted by aansari View Post
    ....please, when approve or disapprove something it will be nice to explain that a little more....
    Best regards, Josip
    Feb 2008
    Suadi arabia
    7
    Dear Josip
    I am sorry for that. It is a vey well known fact that CA and MA dose not work unless there is a control in both T and RH. The edia on both technologies is to control the repiration, respiration is a function of temeprature so it must lowered based on several facts variaty among them.
    I apologize agian for you.
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, aansari
    Dear Josib
    I am sorry for that. It is a vey well known fact that CA and MA dose not work unless there is a control in both T and RH. The edia on both technology is to control the repiration, respiration is a function of temeprature so it must lowered based on several facts varite among them.
    Thanks, I know a little about that, but here can be some other members not knowing what and why and for that reason we are trying to give a kind of full explanation or at least our opinion (what we are thinking about, usually right but sometimes wrong)
    ...... I believe you misinterpret post of Samarjit Sen...
    Quote Originally Posted by Samarjit Sen
    Best regards, Josip
    May 2006
    India
    82
    1,013
    Hello aansari,
    It appears that you have misinterprated my reply. I am fully aware that CA & MA has to be with refrigeration, and a person saying CA etc means the complete system. Josip has explained the situation .
    May 2008
    ca
    8
    i think it's finding a proper place like a cold room with the appropriate humidity. this will help.
  19. #19
    May 2008
    ca
    8
    just do not store them for too long.
  20. #20
    Sep 2008
    Sri -Lanka
    Quote Originally Posted by jong0726 View Post
    What would be the Ideal Type of humidifier Warm Air Or Cold Air? Is there any justification in using a warm mist Humidifier (steam) in a cold room??
  21. #21
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, Cnanna M
    Quote Originally Posted by Channa M View Post
    please, try to search RE forums... there were some posts about types of humidifiers ....
    .... typing word "humidifier" in search window .... found about 60 threads ..
    Best regards, Josip
  22. #22
    Sep 2008
    Sri -Lanka
    Hi josip Thanks very much
    Channa
  23. #23
    Nov 2008
    Foshan,Guangdong,China
    22
    add a humidity controller in the cold room.
  1. Fresh air, building regs 10 l/s per person
    By Andy W in forum Air Conditioning
    Last Post: 10-01-2008, 07:01 PM
  2. Fresh Air Wall splits
    By gwilliamson in forum Air Conditioning
    Last Post: 23-03-2007, 06:03 PM
  3. hydraulic floor heating issue
    Last Post: 02-01-2007, 09:07 PM
  4. total fresh air handler
    Last Post: 19-12-2005, 09:31 AM
