    joaocruz's Avatar
    joaocruz Guest
    ammonia (NH3) condensers selection
    Hi all! I am a student from Portugal i am currently frequenting a masters in refrigeration climatization and energy. In on of the subjects i have this semester (refrigeration) we have to project a warehouse for fish conservation this warehouse is formed by 3 principal rooms a fast frizzing room a preparation room and a frozen fish conservation room.
    All the loads calculations are made (thermal balance)
    the fluids are:
    Ammonia (NH3) and glycol
    Is there any software that could help me selecting the ammonia condensing units?
    Croatia
    68
    2,263
    Re: ammonia (NH3) condensers selection
    Hi, joaocruz
    Welcome to RE forums....
    we also have one forum: New to RE for first post to introduce yourself
    Quote Originally Posted by joaocruz View Post
    the fluids are:
    Anyhow, please try those links:
    Handbook
    http://www.baltimoreaircoil.com/engl...book/index.php
    Software
    http://www.baltimoreaircoil.com/engl...s/ec/index.php
    You can search Evapco site for another software....
    One more excellent software CoolPack: need registration but it is free
    http://www.et.web.mek.dtu.dk/Coolpac...-download.html
    ....hope this will be of some help to you
    one more thing...searching RE forums you can find a lot of links to different info...books, software, etc...just try
    Best regards, Josip
    Split Croatia
    6,151
    Hi, joaocruz
    For those who are terrified of registration of any kind, there is link for direct download of CoolPack great and free software: http://tinyurl.com/3yt3w3
    Aug 2005
    5,302
    Are you going to school to learn how to use software or to learn how to do engineering?
    Almost all ammonia systems are custom engineered to the specific operating conditions and capacity requirements. If you know your cooling loads and operating conditions we might be able to assist you (a little bit, after all you are the one trying to learn this).
    Shortcuts using any software should only be used by experienced engineers, not by someone trying to learn. I say this because you will not have any feeling for answers generated by the software.
    Unfortunately, the only way to develop this understanding is to do the math yourself.
    Split Croatia
    6,151
    To add to that, any software is just a tool. If you don't know how to use it and what to do with it, than it can not help you much. But if you know what are you want and do, than time and effort saving is huge.
    Aug 2005
    5,302
    Just as you would not use a screw driver when you need a chisel.
    Croatia
    68
    2,263
    Hi, US Iceman
    I will not bet on this....you must know what Einstein said about endless things....
    Quote Originally Posted by Albert Einstein
    "There are only two endless things in the world: the universe and the human stupidity... but I'm not sure in the first one"
    Coming back to original post....
    the fluids are:
    No one word about help.....but never to late for original poster to come back and ask
    Best regards, Josip
    joaocruz's Avatar
    joaocruz Guest
    for the conservation (freeze fish) room the conditions are:
    Dimensions 20*60*7.5 m
    outside conditions: t=35ºC and HR (relative humidity 50%)
    Temperature -25ºc
    entering product temperature : -15ºc
    Relative humidity 50%
    daily product entry 8% of the volume
    density of occupation 350 kg/m3
    compressors work 18H day
    load to remove (evaporators) : 140.7 Kw affected by 20% coefficient regarding the heat produced by the motors actuating the fans of the evaporators
    I am considering the installation of 5 evaporators
    Aug 2005
    5,302
    If the heat load is 140.7 kW then you have to add the 20% (of the fan motor heat) to the cooling load. The evaporators have to cool the heat load plus the fan motor heat.
    Then you will have defrosts. A rough rule-of-thumb is if you have 4 defrosts per 24 hours, then the cooling time (24-4=20) available to meet total heat load increases the minimum required capacity of the evaporators. This assumes the total defrost cycle is no greater than 1 hour.
    What you will end up with is something like this:
    (140kW *1.20) / (20/24) / 5 evaporators = 40.3 kW per coil.
    Therefore, when one coil is in defrost the other coils can still provide sufficient capacity to meet the cooling load.
    Now, if your room temperature is -25C, then this means your evaporating temperature has to be colder for the evaporator to work.
    Room temperature - evaporating temperature = degrees of temperature difference to select evaporator.
    Since you will have pressure loss through the suciton line (from the evaporator to the compressor suction) you have to account for the pressure loss.
    Did the professor address any of the above?
  1. Liquid Ammonia Pump Selection & details
    By smpsmp45 in forum NH3
    Last Post: 20-07-2010, 09:53 AM
  2. Replies: 9
    Last Post: 30-01-2009, 07:50 AM
  3. Want to be trained as an ammonia operator
    By Randy Williams in forum NH3
    Last Post: 26-11-2008, 08:15 PM
  4. Replies: 21
    Last Post: 03-02-2008, 05:10 PM
  5. Ammonia and CO2 reactor
    By gwapa in forum NH3
    Last Post: 07-01-2007, 04:50 PM
