Results 1 to 13 of 13
26-02-2008, 12:22 AM #1
Re: Never Mind What Oil, How much is the Question?
I did the same once(in my earlier days) when i came to a 7.5hp prestcold that had no oil in it so i put a load in it just to make the oil pressure switch.20 mins later i had the customer on the phone saying the compessor was moaning like the millenium falcon, you live and learn.
Put the screwdriver down and step away from the expansion valve !!!! OK Gary i won't touch it unless instructed.
26-02-2008, 09:08 PM #2
When changing the oil weigh or measure the amount of oil you take out and only put the same amount in plus up to a max of 10%. Run the system at least one hour in full load and check oil level according to the manual (running or standing still).
Never ever put the standard amount in after an oil change! You'll overfill it for sure!
26-02-2008, 09:28 PM #3
Run the system at least one hour in full load and check oil level according to the manual (running or standing still).It's also important to spend time with the equipment when adding oil as it can appear to be correctly charged one minute then can be over filled as oil is returned to the compressor under certain operating conditions.And never add oil to a system where you are not 110% sure that it has a full charge of refrigerant.
I lost count of how often I seen compressors overcharged with oil after refrigerant leaks have been repaired and the system re-gassed.
When a compressor/ system runs for a long time unloaded. Oil is "carried over" into the system but!
Because the swept gas volumes are low the oil is not returned to the compressor.
Basically ( AS ALREADY STATED) never assume a system is short of Oil, especially if it runs unloaded for long lengths of time and Always fully load a system before any maintenance checks / diagnosis is carried out.
Sight Glasses, Oil or Refrigerant are useless until full load conditions are achieved especially true on Chiller Systems.
Hopefully someone has benefited from this info?
Cheers Grizzly
Heat Transfer Exam Question
By alexdouglas1969 in forum FundamentalsReplies: 10Last Post: 13-12-2008, 04:19 PM -
Hitachi RAC25NH5 question
By Yonas in forum Heat PumpsReplies: 11Last Post: 30-01-2008, 10:53 AM -
Newbie with a question
By AcidSlasher in forum FundamentalsReplies: 4Last Post: 07-03-2006, 11:20 AM -
quizy type question thingy
By rbartlett in forum Chit Chat & Service StoriesReplies: 25Last Post: 06-02-2006, 09:22 PM -
Urgent, Kirchoff question
By Peter_1 in forum FundamentalsReplies: 4Last Post: 20-01-2004, 03:12 PM
