Results 1 to 12 of 12
    Jul 2007
    malaysia
    15
    question about chiller
    how can i calculate a water tank size is 5' x 40' x 5'(H) and the temp. is from 31 celsius to 28 celsius need how many KW chiller ?
    Oct 2001
    Nottingham UK
    5,667
    Re: question about chiller
    Use the formula Q =mcdt
    Where
    Q = duty in kW
    m = mass flow (kg/s)
    c = specific heat capacity (water = 4.19)
    dt = difference in temperature required
    What you are lacking at the moment though is a time scale. How long do you want the chiller to take to reduce the water temperature?
    From the tank size we can calculate the mass of water at 28.316 metric tonnes or 28316kg or 28316litres
    Feb 2007
    2,473
    45
    Another missing bit,
    What heatload is there on the tank?
    Jul 2007
    malaysia
    15
    tat is an aquarium . now the chiller is want maintain the temp in 28 celsius from 32 celsius.
    Oct 2001
    Nottingham UK
    5,667
    I give up?
    Steven - how long do you want the chiller to take to bring the temperature down?
    How much external heat is the tank exposed to?
    Jul 2007
    malaysia
    15
    i want to reduce the temp in 3hrs o something . the ambient temp is 35 celsius .
    Oct 2001
    Nottingham UK
    5,667
    Quote Originally Posted by steven86 View Post
    Now we are getting somewhere.
    If we divide the tank volume by 3 hours (10800 secs) we get 2.62 l/s
    so, Q = 2.62 x 4.19 x 3 = 32.93kW
    Assuming that you don't have excessive external heat gains to the tank, a 35kW chiller will do the job.
    Oh, and make sure the fish don't end up in the heat exchanger circuit
    Feb 2007
    2,473
    45
    Hmmm,
    I'm too lazy to do the maths but 35kW for an aquarium
    Oct 2001
    Nottingham UK
    5,667
    Quote Originally Posted by The Viking View Post
    Hmmm,
    Considering that the volume weighs over 28 tonnes, it's not surprising.
    You can only work with the figures.
    I would have thought that initial pull down over 24 hours would have been sufficient, but, hey ho - what do I know about aquariums
    Jul 2007
    malaysia
    15
    Talking Re: question about chiller
    thanks ya !!!
    Oct 2001
    Nottingham UK
    5,667
    If you can live with a 24 hour pulldown then a 4.2kW chiller will do it
    Saves a LOT of money both on purchase and running costs
    Jul 2007
    malaysia
    15
    ok ... thanks
  1. VRV/VRF vs Chiller (heat pump)
    By nike123 in forum Technical Discussions
    Last Post: 09-06-2011, 03:21 PM
  2. process chiller help
    By talon771 in forum Industrial
    Last Post: 12-01-2011, 08:42 PM
  3. Dunham Bush Chiller Alarm
    By Regulator in forum Air Conditioning
    Last Post: 08-12-2010, 01:42 AM
  4. DIY aquarium chiller
    By BarraCuda in forum Technical Discussions
    Last Post: 06-10-2010, 11:02 PM
  5. Absorbtion chiller Question
    By balerjoe in forum Industrial
    Last Post: 28-03-2009, 09:12 AM
