Results 1 to 14 of 14
    Apr 2006
    Canada
    154
    R-134a Advantages
    I would like to know the advantages involved by using R-134a.
    I've seen a big drop in BTU output, if compared to R-22 or R404a.
    Other than the refrigerant has no blend, what are the other reasons to use R-134a?
    Regards.
    Apr 2006
    41
    1,620
    Re: R-134a Advantages
    Honestly? I can't think of any, it seems to be a rather limp gas, but seems good for high temp hermetic chillers thats about it.
    Feb 2008
    Las Vegas, NV
    67
    330
    What MG pony's says and I like his wording "limp" when it comes to replacing good old R-12. I'll add that it works pretty good for MHT coolers and for autos here in the states. Both my cars have it and it works good here in Nevada, you know 115F, it's a dry heat.
    Jul 2006
    73
    865
    26
    Quote Originally Posted by powell View Post
    it's a dry heat.
    A dry heat? Sounds like my relatives in Arizona. 115F and they say "But it's a dry heat"
    I think the sun has melted their brains.
    Apr 2006
    41
    1,620
    Quote Originally Posted by MRcoolingMAGIC View Post
    Both running pressures/temps are fairly low comparing to other gases.
    If you want that put in R-290! It'll kick the living $h*t out of R-134a!
    Apr 2006
    Canada
    154
    Thanks ALL for the nice comments
    Jul 2001
    Sydney, Australia
    753
    Laughing hard at these two comments
    R134a is not a fave of mine thats for sure, theres a trend over here putting it in place of MT and HT R507 and R404a systems (copying europe) due to the GWP, lets fork out more on capital equipment costs then more again to keep the thing running energy wise
    ...and she said "give it to me you big fridgie"
    west midlands
    98
    Unhappy Re: R-134a Advantages
    R134 a, Advantages, non flammable,non toxic HFC Not Cfc. Low boiling point Low cost.
    Thats about it.
    Disadvantages non miscible / Hygroscopic
    Gwp 1300, Molecular Structure,
    Thats all i can think of,
    Sparrow
    Always easy on the eye.
    Apr 2006
    41
    1,620
    Its still toxic if it burns, it will burn happily if hot enough. So still no real advantage, plenty of immagined ones but verry little real ones.
    Apr 2006
    41
    1,620
    Quote Originally Posted by 750 Valve View Post
    It works ok for the high temp stuff like A/C or high temp chillers but other then that not much ells, even then an HC would make a far superior replacement
    Nov 2006
    Scotland
    43
    85
    Seems like all engineers have their opinions over R134A.Its got its positives and negatives,I guess.Seeing that its regarded as a medium temp gas,i still prefer R404A,seeing it can be used in medium and low temp applications,and it contains a percentage of R134A.Just a thought...
    Jul 2001
    Sydney, Australia
    753
    Quote Originally Posted by Springbok View Post
    for patent reasons ONLY, R507 is the same thing as R404a minus that teency weency bit of R134a
    Feb 2008
    queens park london
    41
    r134-a is mostly used for refrigeration purposes and is not ideally for air cons R22 AND R404a are mostly uses for them cause they are mainly ****tail gasses which R134 a is not so much
    Mar 2008
    Chicago
    7
    Quote Originally Posted by techie View Post
    I tend to disagree . I service alot of Carrier screw chillers with R134a as the juice .
  1. Refrigeration Capacity with R 134a
    By Samarjit Sen in forum Refrigerants
    Last Post: 02-06-2009, 02:28 AM
  2. r600a or 134a
    By Minestrone Dave in forum Refrigerants
    Last Post: 02-06-2008, 07:57 AM
  3. Procedure for changing compressor (134a) please
    By Egan Technical in forum Domestic
    Last Post: 10-02-2008, 12:03 AM
  4. 134a surge drum sizing
    By Camille in forum Refrigerants
    Last Post: 03-03-2006, 01:44 PM
  5. R409a and 134a as r12 replacements
    By Les Stuart in forum Technical Discussions
    Last Post: 02-04-2003, 01:41 PM
