30-01-2011, 03:29 AM #1
Unknown icon appearing on display..
hi, i rent and the Chunlan unit i have is displaying this icon in the pic on the right, dont have a user manual so cant tell what it means... any help?
cheers
30-01-2011, 10:44 AM #2
Re: Unknown icon appearing on display..
I would hazard a guess, as I do not know the unit you refer to, that the top L/H icon is the 'power on'
the snowflake tells me that it is in cooling mode and the symbol on the right of a compressor indicates that the outdoor unit is operational.
Oh, and the set point is 24C
30-01-2011, 11:00 AM #3
Yes, that's the icon for a rotary compressor with muffler. I suppose it just shows "the compressor is on".
30-01-2011, 05:06 PM #4
Or it suddenly recently appeared (cooled, heated fine without that icon previously), could be an icon of an upright vacuum, ie, clean filter. Just guessing here, but I assume you're asking because the icon appeared for the first time?
If not, and it's always been there on and off, then disregard my guess because it probably means compressor as said before.Last edited by paul_h; 30-01-2011 at 05:10 PM.
31-01-2011, 05:06 PM #5
The icon means, compressor is on. It also means that the led is OK.
Many manufacturers have an icon of a compressor on their controllers so I guess AC split manufacturers adopted that idea.
Display problem with Samsung RS60
By ice monkey in forum Trouble ShootingReplies: 1Last Post: 30-08-2010, 03:45 PM -
Structual Concepts Display case and a phamtom fault
By jimmylcoleman in forum Technical DiscussionsReplies: 2Last Post: 08-02-2010, 02:42 AM -
Hotpoint HME400N Fridge Freezer message on display:
By back2space in forum DomesticReplies: 0Last Post: 30-01-2010, 09:14 PM -
Samsung RS21DCSV1 Flashing Display
By leon in forum DomesticReplies: 5Last Post: 07-07-2009, 10:10 PM -
a frozen book display case
By tempo in forum Technical DiscussionsReplies: 3Last Post: 15-08-2008, 07:20 PM
