    vj.star4u's Avatar
    vj.star4u Guest
    Difference Between Vrv And Vrf
    Dear all
    If any one has detailed information between the difference between VRV and VRF,please send that to me .Please send that to my email id [EMAIL= E mail address removed by the moderator. [/EMAIL].
    its urgent.
    Vijay anand
    Mar 2006
    Australia
    28
    Re: Difference Between Vrv And Vrf
    They are essentially the same thing, EXCEPT the term VRV is copyrighted by daikin. for example a system by daikin may be called a VRV, but a similar system made by fujitsu is a VRF.
    VRV = Variable Refrigerant Volume, VRF = Variable Refrigerant Flow.
    Aug 2001
    1,060
    It's as Acidslasher remarked.
    They are two interchangeable terms for the same machine. It means the same.
    Following Daikin's registration of 'VRV' as a 'trade name', VRF has become the accepted generic term for these machines.
    Nov 2006
    Cheshire, UK
    361
    12
    VRF as used by Mitsi and others is the more acurate term.
    VRF - Variable Refrigerant Flow is essentialy what goes on inside the system.
    VRV - Variable Refrigerant Volume does not really happen so therefore Daikin can keep their Guarded terminology!
    Mar 2006
    Australia
    28
    yeah the actual volume of refrigerant doesnt change, so i dont know why its called variable. Flow is much more accurate.
    claws's Avatar
    claws Guest
    Quote Originally Posted by AcidSlasher View Post
    Refrigerants, when they exist in gaseous state, they are compressible and so their volume can be varied.
    Sep 2009
    Scotland
    374
    11
    Quote Originally Posted by sinewave View Post
    I think you will find Daikin invented and patented the first VRV system. Other manufactures then followed by designing there own VRF system, most of which were copies.
    Personally I think the latest VRV heat recovery is far superior to the present VRF systems:
    Higher COP
    Continuous heating during defrost
    No capacity loss during indoor mode change
    Heating mode high capacity start up (providing rapid heat up of indoor coils)
