    Aug 2005
    5,302
    Selection of Liquid-Vapor Separators
    I thought some of you may be interested in this topic so here are some links for your review.
    www.ptac.org/env/dl/envp0102.doc
    http://igs.nigc.ir/igs/BANK-MATN/IPS/e-pr-880.pdf
    http://www.amistco.com/spanish/tech105.htm
    Please remember these are based on conventional practice in the oil & gas industries, but the physics apply to refrigeration also. It is also important to recognize the use of refrigerant or refrigerant and oil may require adjustment of the parameters to meet any requirements you may have.
    If you use the above you should proceed with caution if you have not designed separators before.
    Mar 2006
    China
    83
    Re: Selection of Liquid-Vapor Separators
    studying......
    malaysia
    159
    very resourceful ...
    i feel the basic of such vessel should consider the below few points.
    1] sudden surge of liquid returning to the vessel;
    2] required vaporation rate;
    3] prevent liquid being trasnfer into suction piping
    4] other safety issues
    hope it helps.
    Hendry
    "What uncertainty means to you, and you only?"
    Nov 2006
    Poland
    91
    Hello US Iceman,
    As you know, I am investigating pump refrigeration systems. Link http://igs.nigc.ir/igs/BANK-MATN/IPS/e-pr-880.pdf does not work - could you possibly send me this paper?
    Thank you in advance.
    Jacek
    Croatia
    68
    2,263
    Hi, Jacek
    Quote Originally Posted by Jacek View Post
    Hello US Iceman,
    Jacek
    Maybe you can try here...
    http://igs.nigc.ir/ips/pr/e-pr-880.pdf
    or here for some more info
    http://igs.nigc.ir/igs/search-out.ht...sa=Search#1292
    Best regards, Josip
    Mar 2005
    638
    My experience with separators designed by oil and gas folks is that they are not well suited to a refrigeration compressor suction. They tend to accept up to 1% liquid droplet carry over and allow for higher pressure drops.
    So be very careful using this data.
    Ken
  1. Liquid Ammonia Pump Selection & details
    By smpsmp45 in forum NH3
    Last Post: 20-07-2010, 09:53 AM
  2. Suction gas <-> liquid line heat exchange and performance gains
    Last Post: 18-05-2010, 01:52 PM
  3. Liquid line for multi evaporators
    By Kevin Yeo in forum Supermarket Refrigeration
    Last Post: 29-12-2005, 02:29 PM
  4. Parker levels in ammonia systems
    By Friobernal in forum Industrial
    Last Post: 04-08-2005, 03:46 PM
